02 Transam Bolt in 9" install help?
I have a 2002 transam which Id like to put a 9" in, Got the rear and a new DS with correct ujoint etc, its a direct bolt in rear. Does anyone have an install guide as to how i put this sucker in? Id like to attempt to do this my self. Thanks again!
LS1Tech Sponsor
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
![](https://ls1tech.com/forums/signaturepics/sigpic168855_1.gif)
LS1Tech Sponsor
From BMR's website.
Set the pinion angle using the following method:
Load the rear axle by either setting the car on the ground or letting the car rest on jack stands positioned under the rear axle.
Place the angle finder on the driveshaft and record the angle. The driveshaft angle is negative if it slopes downward towards the rear of the car. The driveshaft angle is positive if it slopes upward towards the rear of the car.
Now place the angle finder on the rear end torque arm mounting plate and record the angle. The rear end angle is negative if it slopes downward towards the front of the car. The rear end angle is positive if it slopes upward towards the front of the car.
Add the two measurements. This is your pinion angle. (Example: -2 rear end angle plus -1 driveshaft angle = -3 degrees)
Turn adjuster to achieve the desired angle.
As a starting point, most F-Bodies seem to like the following initial settings: Automatics: 1-2 degrees negative Manuals: 2-3 degrees negative
Please refer to www.bmrfabrication.com to view the video for setting the pinion angle.
Once pinion angle has been set, tighten all jam nuts and rear bracket cross bolts.
Bob
Bob
__________________
LS1Tech Sponsor
__________________
