02 TA Rear end removal Jack stand location?
Old 06-21-2011, 06:20 PM
Patsy57's Avatar
Default 02 TA Rear end removal Jack stand location?
Im going to be swapping my rear out of my car and was wondering where i put the jack stands? Any help would be greatly appreciated.
Thanks
Old 06-21-2011, 06:36 PM
BrianSF-GA's Avatar
This was my S60 install, but I have SFC's.
Old 06-21-2011, 07:03 PM
jetaws6's Avatar
There's a rectangle jack point right in front of the tires.
Old 06-21-2011, 10:54 PM
01ssreda4's Avatar
Agreed, the spots are already there you just need to make yourself familiar with them.
Old 06-23-2011, 06:50 AM
Patsy57's Avatar
Why is there wood in that picture?
Old 06-23-2011, 08:14 AM
BrianSF-GA's Avatar
Two reasons ... I did not want to scar up my front subframe or my SFC's and I did not like the way the stands fit under the subframe/SFC's. As an afterthought, it gave me 1-1/2" more height for the installation as well.
Old 06-23-2011, 08:22 AM
Internet Mechanic
BlackScreaminMachine's Avatar
Use a rag if your worried. You can use the spot where the LCA meets the body so as long as you leave the LCA in place to keep it stable. The LCA if the jack is positioned correctly will move down a good bit. Or use the factory points.
Biggest thing you should have is a helper so 2 hands are better then one. One for the jack, one for the rear. Make sure you un hook the ABS sensor either at the end of the axle (4 channel w/ TCS/ASR) or 3 Channel @ the top of the diff (no Trac control).
Old 06-23-2011, 09:49 AM
Patsy57's Avatar
How long do ou think it will take to do the swap?
Old 06-23-2011, 09:52 AM
Mystery Bird's Avatar
One of one swap with help, couple of hours or less.
Old 06-23-2011, 10:04 AM
BrianSF-GA's Avatar
It could easily be done in a looooong day or a weekend. It took me several weekends because I did not work on it continuously every weekend. I took time researching the install to death, prepping and coating the rear, modifying my motorcycle lift to work with the rear, massaged my fender wells and bump stops to fit the 315's/11's, added full Spohn rear suspension parts, etc., etc. Basically, I took my time!
Old 06-25-2011, 08:56 AM
shawn_c992001's Avatar
I swapped mine in about 2 weekends. The last day I had a Big buddy of mine come help me to get the rear under the car and into place. Once you get started it is pretty straight forward. I highly recommend a trans jack when installing the bigger rear.
Old 06-26-2011, 07:28 PM
Patsy57's Avatar
After you swapped it did you have to update the computer to reflect the new gear ratio?
Old 06-27-2011, 02:41 PM
need4fun2469's Avatar
yes, the speedo will be off and if an a4 the shift points will need to be adjusted.
Quick Reply: 02 TA Rear end removal Jack stand location?
