K&W Trans-X Posi Trac Additive vs. GM Limited Slip Additive
Just finished a gear swap and had a question about additive. I'm sure that's what my problem is, just wanted to hear other opinions. It makes what sounds like a brake squeal when turning left only it seems. Everything was perfect with the rear, just swapped gears and put it back together. I added 2 qts of 80w90 dino and a full bottle of the K&W additive from Advance Auto. Mine has an Auburn, not Torsen. I've put 15-20 miles on it since the swap. When I changed my diff fluid in my Lt1, I used the acutal GM additive with no problems, never used the Trans-X stuff.
I've got some other things going on and it may be a few weeks before I can mess with it. I know my rear brakes were a little worn, but not on the wear indicators yet. I'm gonna double check that and give it a few more miles before I change the fluid.
Anybody ever used the Trans-X stuff with good luck?
https://ls1tech.com/forums/gears-axl...-additive.html
Found this that sort of answered my question. Anybody else have any thoughts?
