rear end probs
On the other hand You might consider looking into a S60!
Carl
One wheel peel is just the low torque biasing range
of the factory Torsen, being less than the ratio of
static to kinetic friction of the tires to the road (less
wheel lift suspension reaction which is also stealing
tire down force).
Factory Torsen only has about a 2:1 bias range and
it's not uncommon for static/sliding "mu" values to
differ by way more than that.
Once you jerk the passenger's wheel up and spin it,
you'll only put 2X that to the still-stuck driver's
wheel and never exceed the breakaway torque.
If this is your only problem then it's a good problem
because spinning the second tire is going to likely
apply less road friction force than once you slide it.
A high-bias diff (like T-2R) will give you more torque
to the stuck wheel -up to the breakaway point- but
after that it's all back to tires no matter what chunk.
