putting 4 channel rear end in 3 channel car
ok my 3 channel stock rear end is toast. i found a 4 channel one. question is, if i put it on, will my abs not work? will the lights come on? will it not pass inspection? obviously i will not have tcs, but can it be hooked up?
NEED AN ANSWER ASAP OR IM GOING TO LOOSE OUT ON THIS ONE AND HAVE TO FIND ANOTHER
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
you can make them work but you have to drill a hole in the top of the housing and change the internal reluctor ring to the 4 chn. i would just keep looking if i were you. you should be able to find a good 3chn
yeah... its just a risk... and i need it to work. i can only afford to do this this one last time. (already had to get one new rear for this car). trouble is i need it fixed soon....
if i get this one and put it in, i believe all my brake lights will come on (hand brake, abs, and well, i dont have it, but tcs or maybe low trac or something) but if that happens, how can i get them all off? especially ABS and BRAKE
