At the track with you 10 bolt??
, but at least I drove home.
The only way the words "launch" and "10 bolt" belong in the same sentence is "I'm going to launch my 10 bolt in favor of a 9" or 12 bolt." Clutch dumping on the 10 and sticky tires is suicide, that's why slipping the clutch will save it a little.
The only way the words "launch" and "10 bolt" belong in the same sentence is "I'm going to launch my 10 bolt in favor of a 9" or 12 bolt." Clutch dumping on the 10 and sticky tires is suicide, that's why slipping the clutch will save it a little.[/QUOTyea i argee on you with that one!!! what size tires are you on ?
I service the rear every year if not sooner. I have some noise coming from the rear, but I am sure that is the bearings since it sounds like a bad wheel hub.
First time at the track with the 6sp and 4.10 and blew the rear shifting into second on the second run.
It's a crapshoot
If you have more than bolt on power, or you have bolt ons, a good clutch, and sticky tires, you better be prepared to upgrade that rear.
11.96 @ 115. 1.79 60'
I weigh 254lbs.
That was the best time I have gotten, been faster with slower ET but the rear is as good now as it was brand new from the factory. Car has 57K.
I'm building a 427 that should make 575 -600 at the wheels. Reflashing the stall to 4200 with a Performabuilt Level II. Got a new Detroit locker, Moser axels, Richmond 4:10 and all new bearings, seals & gaskets as well as the T/A Stud girdle kit for the *** end.
We will see how it holds up this fall at the track on drag radials!
Chad
With that said, when your talking about a manual car/10 bolt combo with any kind of tire and any kind of clutch at all, its not a matter of if the rear will break, its when.
I weigh 254lbs.
Chad
