4.10 in a 10 bolt
Old Aug 19, 2011 | 10:12 PM
02 Camaro's Avatar
Default 4.10 in a 10 bolt
I was just wondering if a set of 4.10 gears would fit in my stock 10 bolt. It has 2.73s in there now. any help would be appreciated
Old Aug 19, 2011 | 10:25 PM
01ssreda4's Avatar
Yep, but you will need the thick cut 4.10s for a 2 series carrier.
Old Aug 19, 2011 | 10:26 PM
Sales1@Texas-speed's Avatar
PM sent!
Old Aug 19, 2011 | 10:58 PM
02 Camaro's Avatar
Does anyone know if these would fit, its a link to the classifieds
https://ls1tech.com/forums/parts-cla...us-bottle.html
Old Aug 19, 2011 | 11:19 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
since the ad doesn't state if they're 2 series or 3 series(probably 3 series),you'd have to PM the seller to find out. 2series required for your 2.73 carrier. Most 4.10s are ordered for 6 speeds which are 3 series carriers.
Old Aug 20, 2011 | 11:59 AM
If the gears are meant for a 3 series carrier make sure to purchase a spacer for the ring gear to correctly install them into your 2 series carrier.
Old Aug 20, 2011 | 04:51 PM
01ssreda4's Avatar
I would choose not to use a ring gear spacer. I would buy the correct gear for the application.
Old Aug 20, 2011 | 05:10 PM
^^^ no spacer,buy/acquire the proper gearset !
https://ls1tech.com/forums/gears-axl...s-carrier.html
Old Aug 21, 2011 | 09:36 AM
^Agreed if buying new definitely purchase the correct gear for your application. I was just stating that if he does decide to purchase a used set most likely they will be for a three series carrier and a spacer will be needed. The seller should be able to answer that question for him before purchase.
