diff covers. T/A griddle vs. AAM cover
Any advice on which one to get? I am leaning heavily towards the AAM, unless the T/A has significant improvements over the AAM on a STREET car.
AAM:
T/A:
Please don't say "don't waist your money on the 10 bolt, go to a 9 inch." This is not a daily driver and not a track car. Just a nice day cruiser.
Thanks
Thanks
I bought a TA cover with the ARP carrier bearing cap stud kit. The TA cover is a very high quality piece with nice machining made in the USA out of 356 alloy heat treated to T6 hardness, which makes for a pretty nice piece of aluminum.....
What makes it better than the T/A? The price defintaly isn't it.
Exactly. The axle tubes in a 10-bolt are just pressed into the center housing with maybe a single tack weld. Some people go through the hassle of welding in the axle tubes, but that takes a good bit of work since it's a cast iron peice which takes quite a bit of heat. You have to remove the bearings or else they will get damaged during the process. So to keep the axle tubes from flexing, the braces should help. How much, not sure, but for a street car, it will probably help.
It's perfume on a pig, but atleast you'll know you tried.
