Does anyone's 10-bolt pinion seal NOT leak?
Old 10-15-2004, 04:04 PM
97LT1's Avatar
Originally Posted by 00 Z-28
I had a 2000 Z28 w/M6. Mine leaked from day one. When I got my 3.73's put in the installer (Pyle Brothers) recommeded installing a yoke kit also(has a outer seal on it), besides the new pinion seal. Never leaked afterwards.
Pyle brothers did mine as well and never had a leak.
Old 10-15-2004, 04:10 PM
firechicken2k's Avatar
definitely a member of the pinion seal leakers
but i just had it fixed today
i'm curious to see if it'll start up in the near future
Old 10-16-2004, 04:52 PM
98 Silver Bullet's Avatar
2 things that can help: apply a small amount of RTV around the outside of the seal before installing and find something to install it straight such as a large socket or pipe fitting. Also remove the tension spring before you install it. The tension spring comes apart. One end is tapered and it basically screws into itself. Take it apart and cut about 1/8" or so off the big end and re-install the tension spring. The seal may not last as long but it should help the leaking.
Old 10-22-2004, 10:20 AM
skunk50's Avatar
well mine is perspiring
Old 10-22-2004, 10:34 AM
B T
B T's Avatar
My 01 Z28 seems to be fine, but with 33,000 miles on it I need to change the fluid so after the cover comes of it'll leak...
Old 10-22-2004, 12:07 PM
daryl2cb@yahoo.com's Avatar
The sweating is most likely the vent tube, or lack of vent tube. Get the one from the truck rear and vent it, this stopped my sweating. there is a post that list GM numbers on this, I am at work now, I have the link written down at home, if any one has interest, PM me.
Old 10-22-2004, 12:10 PM
Kleeborp the Moderator™
MeentSS02's Avatar
Mine leaks, but I'm gonna drive it into the ground and replace it with a 12 bolt or 9 inch. I hate that it does, but like most, I've never seen a drop of oil on the ground. I guess it just "sweats"...
Steve
Old 10-23-2004, 01:10 PM
HavATampa's Avatar
Thumbs up
Was wondering what yoke kit are you talking about and where can I get one?
Old 10-24-2004, 02:14 AM
DUNGBEETLE's Avatar
Leaking seal, had it fixed for free where i had my gears installed. Said the best and cheapest, and ghettoist (is that a word) way to fix it permanently was to take some of that blue sealing stuff and just put it all around where the metals touch (its ghetto but i heard it works)
Old 10-24-2004, 06:13 AM
Race your car!
JL ws-6's Avatar
3 years, 16K, good so far, not that it matters, as the 10 bolt's going bye bye before it breaks....
Old 10-26-2004, 04:16 PM
TA TECH's Avatar
Default Might be of help!
Well I've seen every rearend I have looked at leak. Except the ones I have rebuilt. GM dealer put 3 in my car under warranty.Still leaked.My axle bearing went out so I decided to put all new bearings and seals in it.When I checked the pinion bearing preload before I took it apart and it had 0 inch pounds of preload. During assembly I put 25 inch pounds preload on pinion. Neverleaked
since or the other 8 to 10 I have built. We all tourture our rears and still hasn't leaked.Well I guess thats a good thing or luck. I think the dealer just didn't no what they where doing thats a shame.
Old 10-27-2004, 10:59 PM
  #32
BigSteele's Avatar
lol, I didnt know this was so common. I just got a 1999 Z28 and I have this problem too. I was starting to get worried but now I know its just the seal.
Old 11-01-2004, 02:09 PM
  #33
Dale Schulz's Avatar
I bought a 2000 WS6 firebird brand new and my pinion seal has never leaked. I have 6 speed manual trans. also but my rearend whines loudly and I will buy a 12 bolt for it next year. My car has 44500mi.
Old 11-03-2005, 09:55 AM
  #34
NewRave's Avatar
Hey,
I got a question for all those who have had pinion seal leaks. I've noticed about 2-3 teaspoons of liquid has collected on my garage floor right under the rear differential when the vehicle is parked. Does anyone else experience this volume?
I got under the car to try and determine the source of the leak, but it was so dirty that I couldn't locate it. An interesting thing to note is that it looks like some type of liquid has sprayed up onto the exhaust right near where the drive shaft and differential connect. Does this happen when the pinion seal is bad?
Thanks!
Old 11-03-2005, 10:51 AM
  #35
Ouija's Avatar
Dunno if you want to call it leaking or sweating, but my 00 and 01 TAs in stock form both had a descent residue on them from something oily seeping out on the diff housing, however not a drop ever hit the floor. Now that I had 3.42's put in the 00 it actually leaks. It's only one or two drops every week or so, but it's still a leak.
Old 11-03-2005, 03:05 PM
  #36
S1LV3R's Avatar
It probably is sweating. Think about it. If you were in it's place and knew you were about to get beat on by that bad *** motor you'd be sweating too. LOL
Old 11-04-2005, 05:15 PM
  #37
LSWon00's Avatar
got 61K on mine and its never leaked.
Old 11-05-2005, 10:04 PM
  #38
02 wife's Avatar
41,000 mile and no leaks!
Old 11-05-2005, 10:25 PM
  #39
Mr Ed's Avatar
Mine never leaked a drop from either the cover or the seal. I only had it for about two years though before I stripped half of the teeth off the gears (twice) and replaced it with a 12-bolt.
Old 11-06-2005, 04:35 AM
  #40
2MuchRiceMakesMeSick's Avatar
Ive never had one or worked on one that didnt leak. I wouldnt even bother trying to fix it, save your money and replace that thing.
Quick Reply: Does anyone's 10-bolt pinion seal NOT leak?
