Need answer fast!!!!!! Spool?
-Strange aluminum center section
-Spool with 3.89 gears
-35 spline gun drilled axles
-1350 strange pinion yoke
-Drag bar welded to the housing
-Stock brake calipers ground down for 15" wheels
-ARP studs
-Adj. torque arm
-T56 transmission mount
-Adj control arms
-Driveshaft with 1350 U Joint (I think its a PST but not positive)
-Adj panhard bar
how streetable would this be?
thanks for the quick repleies
the only thing i would change is the gear ratio to 456.
your an m6,right? what gear are you runnin now?
if your close to 46356 lowell IN. come on by & i will give you a ride in mine, that has a spool.
good luck!
BTW, a spool is fine on the street if you drive responsible in the rain. My old car had a spool and ran high 9's. This car i might be able to squeak in the high 11s this summer and it has a Detroit Locker. The Locker actually feels less friendly on the street than the spool. Go for it..
