You wanted it, Strange delivers. The new aluminum HD 9 inch case
Old 04-03-2012, 09:49 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
Default You wanted it, Strange delivers. The new aluminum HD 9 inch case
MWC is a proud direct dealer for Strange, Moser, Yukon, Motive Gear, and several other manufacturers. I feel it is important to inform the performance community of a great new product from Strange, just as another option to the products MWC manufactures and sells.
It has been labeled the "hybrid" because it is very similar in design to the baddest aluminum center section made... the Strange Ultra Case. The new Strange through-bolt aluminum HD case is a brand new design with the high powered street/strip cars targeted. This new design uses the same huge pinion support bearings as the forged Pro Gear pinion support(N1922), but has the oiling system of the street "Daytona" type pinion support, along with extra gusseting material in the high stress areas. The case has ARP hardware included along with the wider tail bearing for heavier loads at the gear contact area. Note this design really isn't a "through-bolt" but more of a "through stud". No hardware store bolts in this unit, just special designed hardware specifically for this case as it is uses a special designed 9/16 stud instead of a 1/2" bolt. The case and pinion support are a package deal. Due to unrivaled engineering, this case is super strong, yet still lighter than other similar designs out there.
I have been setting up race cars and rearends for 25 years and had my hands on just about every 9 inch center section ever made. I will tell you this is by far the best street/strip aluminum case on the market, and expect nothing less from Strange. Couple this case with the new Strange S-trac 35 spline posi unit(which carries a limited lifetime warranty) and you have a center section never to worry about again.
All in all, this is the latest and greatest technology and is priced very affordable. Guaranteed best deal at MWC as always.
HD case:
http://www.strangeengineering.net/ne...Alum-Case.html
S-Trac 35 spline mechanical posi
http://www.strangeengineering.net/ne...racLayout.html
Pics of the new HD case... This is a unit I setup for Koolrayz here as he is upgrading his new turbo car to all MWC components.
Old 04-03-2012, 12:16 PM
355z28's Avatar
Thats awesome and super beefy. I know this is a better product then the yukon but how does the yukon Thru-bolt compare?
Old 04-05-2012, 01:24 PM
355z28's Avatar
anyone?
Old 04-09-2012, 06:35 PM
ssvert99's Avatar
The Yukon cases are a pretty good piece, especially for the cost. The Yukon case uses a standard grade 8, long 1/2" bolt. The oiling system in a off the shelf Yukon case however is nothing like this design and is more of a race or very limited street use. Over the years of using the Yukon thru-bolt aluminum case we have done custom mods for our customers using them on the street and mods to pinion supports as well to achieve streetable oiling.
The new Strange HD aluminum case is by far the best I have seen for a street/strip aluminum case, and the cost difference is even less compared to the other aluminum thru-bolt cases on the market.
Old 04-11-2012, 08:51 AM
355z28's Avatar
Thank you for taking the time to answer my question. I have had the Yukon for a little while and so far so good. The oiling statement has me a little worried as the car may see the power tour someday.
Old 04-11-2012, 09:16 AM
RAMPANT's Avatar
Looks really nice.
You have me worried about the Yukon center section I bought with my MWC 9". When I ordered it, we discussed that it would be used on the street as well as road coarses with some drag strip visits. I do only expect to put 4-5k on it a year, as it is aweekend toy. Do I have the wrong set up all together? What can I expect to fail? No one suggested any mods to the Yukon center section.
I have the Yukon thru bolt, Wavetrak and the Yukon light weight gears.
It would really suck to have to buy a new center section for a brand new diff.
Old 04-11-2012, 09:46 AM
ssvert99's Avatar
It all depends on the pinion support used, and this is true for any 9 inch rearend. This new design from Strange uses the same size bearings as the pro gear(35 spline) supports and has the advanced oiling system for street use. Chances are is if you purchased a 9 inch from MWC for street use it has the street type pinion support. We have done oiling system mods to those using the big bearing support and driving on the street. Don't worry... MWC does it right!
Old 04-12-2012, 12:18 PM
Big Al's Avatar
Was under the impression that Aluminum cases were not good for street use. Aluminum expands when it gets hot and throws off the gear settings. Is this not true?
Al 95 Z28
Old 04-12-2012, 09:11 PM
ssvert99's Avatar
Just not suggested for a daily driver. We have run aluminum cases on the streets for years without much of any issue.
Old 04-12-2012, 09:36 PM
transam69230's Avatar
Yea i saw this thread as well and am starting worry about my Yukon thru-bolt case as well. I just got mine in the car the other day and haven't even broke it in. I will be putting 3-4 thousand miles on it a year.
Old 04-13-2012, 06:29 AM
ctjohns's Avatar
I really dont think MWC would point you in the wrong direction. I'm sure that your Yukon parts will be fine...there is always something bigger and better that comes around...just after you buy something! Chuck
Old 04-13-2012, 09:20 AM
355z28's Avatar
I feel the same way, I have the thru-bolt and put around 3000-4000 miles on it a year along with a couple road trips (around 500 miles one way) I hope this isnt an issue.
Old 04-13-2012, 12:22 PM
HoLLo's Avatar
This is such a badass case. I'm running a Moser Lightweight Nodular 9 case on my car.. If it ever blows I'll be picking up one of these.
Old 04-13-2012, 09:28 PM
xDIRTYx's Avatar
Looks awesome, cant wait to see mine when it gets here!
Old 04-15-2012, 11:49 AM
soco80p's Avatar
Looks bad ***, strange makes some good stuff
Old 06-09-2013, 06:05 PM
Jasperstang308's Avatar
whats the weight difference between this and the regular ultra case?
Old 09-05-2013, 09:39 PM
I8UR4RD's Avatar
would like to know the answer to the above question.
Old 09-07-2013, 12:17 PM
LS6427's Avatar
As usual.....Strange will never reply to an email.
Does this Strange HD set up work on old Strange 12 bolt rear ends like mine from 2002. It would be a nice upgrade to my rear end.
Old 09-09-2013, 10:20 AM
ssvert99's Avatar
Unfortunately the 12 bolts and 9 inch rearends are totally different form one another. GM produced the 12 bolt, Ford produced the 9". No parts are compatible between the two other than the stock size 9" front pinion bearing.
Old 09-10-2013, 08:34 AM
koolrayz's Avatar
I have both and I can tell you I was shocked at how much lighter the HD is than the ultra case. I have been beating the snot out of this HD case and it has worked great!
Quick Reply: You wanted it, Strange delivers. The new aluminum HD 9 inch case
