spool vs mini spool
Refer to link for an illustration of a spool.
http://www.jegs.com/i/Moser/718/5S9F31/10002/-1
A mini spool is a piece that simply replaces your existing carriers spider gears. It goes inside of your carrier and each axle sides into it. A hardened pin slides through the mini spool (perpendicular to the axles) and into the carrier linking them all together as a locked unit. This setup relies heavily on the hardened pin and is known to commonly break. This setup is not nearly as strong as the spool setup but the end result is the same. Refer to the link for an illustration of a mini spool.
http://www.jegs.com/i/Richmond+Gear/...931-1/10002/-1
A permanently locked rear end will cause a street driven car to track while turning. The outside tire will try to turn at a faster rate of speed resulting in the inside tire chirping (spinning) around the corner. This can cause drive shaft u joint failure or axle shaft failure in heavy, high horsepower, or daily driven applications.
A better solution for a street driven vehicle is a Locker or a limited slip unit. These 2 components will lock the differential, making it a 2 axle drive differential, when a predetermined amount of load is applied. During normal operations, the differential will be open (single axle driven) and have a greater street manners.
