Ford 9" build
But FWIW for that price you can get a Quick Performance bolt in housing with the torque arm mount and spring perches, axles and bearings for not much more.
You can also get a Moser bolt in housing with the torque arm mount with out axles and bearings for less than that Currie cost.
M9 with axles and bearings is 1605 plus 140 if you want the backbrace for the axle tubes, and the 225 for powdercoating.
If you want anything Moser, Bob is you man.
https://ls1tech.com/forums/gears-axl...red-8-8-a.html
https://ls1tech.com/forums/gears-axl...l#post16716724
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Is the case and center section ok for me to use in my trans am or do I need to buy a whole new setup?
You could go with this Moser 9 inch housing and axle package, or go with just the 9 inch housing. If would be easier to go this route than it would be to get those axles to work. Provided those axles are long enough to be shortened, they would have to be cut down and resplined. Bob
