How much can a 10 bolt really hold
Old 10-28-2012, 10:56 PM
lemons12's Avatar
Yes sir.. When it blows I'll switch to a 12bolt. No need for the added weight on a 9" for an auto.
Old 10-28-2012, 10:59 PM
bigantws6's Avatar
My buddy said 600 for a 9" he has but it's from a third gen so I wasn't sure if it will work idk about these things lol
Old 10-29-2012, 02:53 PM
20sickss00's Avatar
Broke mine on saturday, snapped the axle in half. making over 460 to the tires. H/C/I car stock bottom end. Running 27" hoosiers, lasted 5 passes, hit an 11.54 at 122.50 with a not so great 1.78 60 foot. I cut a 1.68 on the pass before but missed a gear so couldve easily a low 11 second pass. this was on a stock 10 bolt with 410s and trickflow cover in a 6 speed ss. This was my first trip to the track on my new build and slicks....so they may last long, or may not haah, cant really put a time on it.
Old 10-29-2012, 08:25 PM
bigantws6's Avatar
Yea that's wild that Gm would put such a weak rearend but guess that 10 bolt can go at anytime
Old 10-29-2012, 08:36 PM
SexyTransAm's Avatar
1.53 60' here hitting a 125 out of the hole. iv seen 50+ passes with 1.5x 60's and its still rockin. 3.42s, 3200 converter, 26" quick time pros. ill see how far i can push it till it goes.
Old 10-29-2012, 08:50 PM
zzracer's Avatar
My car is 3720lbs full weight with the stock 10 bolt,3.23 gears,4000 stall and puts 439 to the wheels. My best 60ft is a 1.53 .My buddies car is similar and he has run 1.46 60ft.Like mentioned already an automatic car is a lot easier on the rear end and it will last a while longer in automatic car. I still expect to break mine any time.
Old 10-29-2012, 09:06 PM
poopman's Avatar
I have broke them in a stock 305 5 speed third gen all the time, they are weak!
Old 10-29-2012, 09:10 PM
HioSSilver's Avatar
I've been 11.1 many times on my m6 10bolt car. But I have broke 2 axles. The trick to making the r&p live is to not use 4.10/4.11 gear. Back off to a 3.90 or 3.73 then break axles. Axles are cheap.
Old 10-29-2012, 09:48 PM
Joe Spinners's Avatar
I broke mine with just bolt-ons lol...and now sport a MWC rearend!
Old 10-29-2012, 09:50 PM
ZTwentyAteU's Avatar
The jolt is what breaks them. They flex. a stock 6 speed car can break one easy.
autos however, go a lot longer. Unless you are hitting one with a transbrake, it prob wont break for a long time
Old 10-30-2012, 12:35 AM
bigantws6's Avatar
Well guess ill run mine until it breaks lol I'm on 3.23 so I guess I'll be fine
Old 10-30-2012, 05:40 AM
  #32
therabidweasel's Avatar
The thing that spooks me about breaking axles are the c clips. 3 wheelin into the wall is not something that interests me. I considered adding c clip eliminators, but it just gets too expensive to not step up.
Old 10-30-2012, 10:13 AM
  #33
bigantws6's Avatar
Imma check into the c clip eliminator
Old 10-30-2012, 11:20 AM
  #34
Grr
Grr's Avatar
they will take allot, I run low 11s and 1.60 short times, 7.2 in the 1/8th all summer and its still going strong. Even with 4.10s. Hope to go 10.8s next year on it
Old 10-30-2012, 11:39 AM
  #35
bigantws6's Avatar
Ur one of the lucky ones brother
  #36
bigantws6's Avatar
Looking into doing the Ford 8.8
Old 10-30-2012, 11:46 AM
  #37
Beave's Avatar
My buddy with a 408 in his running 10.6@129 hasnt broke the 10 bolt yet, that motors been in the car for years.
Old 10-30-2012, 12:47 PM
  #38
bigantws6's Avatar
Imma just run mine to it goes and see how long it will hold with my luck
Old 11-03-2012, 10:19 PM
  #39
Mike Morris's Avatar
Once sixty foots get in the 1.4 range even with a girdle and axle tubes welded its risky.
Get the car light,weld your axle tubes,run a solid crush sleeve and a girdle on an automatic and you should be fine till you get into the 1.4 range.
Old 11-04-2012, 06:19 AM
  #40
HioSSilver's Avatar
I agree with Mike on the auto's.....but damn it...I just broke my 3rd axle with my m6. But atleast the r&p is staying together. Anyone got any good axles so I can get to the 10's???lol
Quick Reply: How much can a 10 bolt really hold
