Pwr level of a 8.8 with a 6speed ?
Old Oct 31, 2012 | 10:22 PM
wantsum410's Avatar
Default Pwr level of a 8.8 with a 6speed ?
The time has come for me to move my built 8.5 10 blt to my '67 Chevelle Wagon that will be runnin an Auto LS Setup...... after 7 yrs behind my M6 LS setup in The ' 72 SS Camaro . Just finished New axles .R & P , bearings ect. & it is not gonna live with the stick anymore.
I am looking at a 8.8 with 35 spline gun drilled Moser Axles , C Clip Elim. ect. How much PWR will it hold , CAR is......
H & C Ls1 M6 all bolt on's = 460 RWH ...420 RWTQ
Coming over winter Dual Stg Plate Kit Leaving on 100 shot
with a 2nd Stg of 100 shot in on 2nd Gear to start with ,
Kit will go to 400HP .
I have been runnin 4:56's for Track & Street , how much Drop in Gear Ratio will be needed for the added Hit of the Plate Kit ?
Old Nov 1, 2012 | 07:35 AM
INIT2WIN's Avatar
My buddy is making 800+rwhp in his 3800lb 07 GT500 M6 with a 3.55 geared, stock axle 8.8! He runs the car pretty hard at the track on slicks and DRs! I would think that your car should be a good bit lighter than his and shouldnt have too many problems out of a built 8.8! Thats just my $.02 though.
Old Nov 1, 2012 | 08:34 AM
wantsum410's Avatar
My Car is 3500lbs with me in it Now & will likely lose at least another 100lbs over the Winter .
Old Nov 1, 2012 | 10:40 AM
OldCobraGuy's Avatar
It will hold a ton more than you have plans for. There are several 800+ HP Mustangs running them with slicks.
Just make sure you build it with quality parts and for the power level you plan to run. In other words, don't plan on using a weak old posi unit behind 800 HP, etc.
Old Nov 1, 2012 | 11:57 AM
Sail Hatan's Avatar
my buddy is running one in his 7 second fox.
Old Nov 1, 2012 | 03:23 PM
venom99's Avatar
guys have thrown 1000 hp at them and no issues you will be fine done use c clip elim though get ford 9inch housing ends on it go with the big bearing ones i have a fully built 8.8 that way in my camaro
Old Nov 1, 2012 | 03:57 PM
96lt1m6's Avatar
You should NOT have any issues with that 8.8 with the internals planned. 35-spline axles are very tough! As mentioned there are MANY fast mustangs running these very same set ups although they are lighter weight than us and can get away with A LOT... You are GOLDEN...
Old Nov 1, 2012 | 05:55 PM
MeentSS02's Avatar
Kleeborp the Moderator™
You don't need the same thread in two different sections. They've been merged.
Old Nov 5, 2012 | 02:59 PM
wantsum410's Avatar
Thanks for all the input ,The Addiction is Stronger than .....me
Any input on Gear Ratio ? Will be sprayin 100 shot off line with another 100 shot in 2nd gear . Have been runnin 4;56's N/A ....I drive my car ALOT on the Street ,4;11's be enuf drop for the added hit of the Bottle ? 28/9/15 MT Slicks .
