Broke stock TA and 12 bolt housing. Any suggestions?
Mind you, this happened on a strong 1-2 shift, I'm not pushing much more than stock power:
More pics at:
http://maverickwh.home.comcast.net/RedSS/12Bolt/
When the TA broke off, it broke the housing where the bolt rear bolt attached. I'm only guessing that the top is just as bad.
I talked to Moser, and they said that the housing is not covered under warranty and want $850 for a new one. Do I have any alternatives at getting it repaired?
I was looking at getting a Random Adj. TA. Do the holes in the moser go all the way through? It appears like some of the aftermarket bolts go all the way through, rather than the stock bolts which don't appear more than an inch long.
Thanks!
More pics at:
Thanks!
The bolts loosened up and it just beat it self to death - common problem - check them bolts often..
You may be able to get it welded by someone who knows what they are doing. Either that or buy an aftermarket torque arm and just get the bracket welded to the housing and be done with it. You could unbolt the arm from the bracket if you needed to remove it.
Ahhh - I like the idea of just welding the bracket to it. Since I already need an aftermarket TA, any good suggestions on them? I'd prefer to get one with the DS loop.
Thanks!
Scott
Thanks!
Scott
Make sure you use red loctite on the torque arm bolts that go into the housing... and check them often. Since it's a four bolt setup rather than 2 bolts that go all the way through, sometimes they can back out if you don't torque them down hard along with a good dose of loctite.
The main problem is the Moser bolts are too small diameter, I'm sure they do it for ease of getting all four of them lined up. Since the hole in the torque arm is a bit larger then the bolt the torque arm moves and loosens up. A couple of the bolts are tapped almost all the way through and using a loger bolt may help since thats more area for the locktite to stick to. Finding some of those thick serrated (sp) washers with the teeth that dig into the torque arm and fit tight on the bolt will help along with the longest bolt possible.
Main thing is to check it fairly regularly, if you check it a couple times and they dont loosen dont feel too confident they wont loosen up in the future, so keep checking them.
The housing not being covered is BS. WTF is that about? So they only cover the axles, Diff and gears? I run a Strange but a good friend of mine has a Moser that I put in. He has to tighten the bolts about once a month. So, I take it $850 means you have to take out the rear and send it to them?
BS!
BS!
That sucks Mav. I read about this problem before I installed my 12 bolt. Seems like peoples bolts loosen up over time. I ended going with some longer grade 8 bolts / washers and used red loc-tite on mine. I then made sure got them tight as I could using my 500 ftlb impact. The top ones are a bitch to get to but with the axle dropped and no shocks, you can do it with an impact. I never had any problems with the bolts coming loose. They are a bitch to get off though if you have to do it with a wrench! I've had some good 1.8 launches on it and no problems with the Edelbrock TA. Hope you get it fixed. Sucks that Moser won't warranty it. That Ford 8.8 option just looks better and better. I pray my Eaton holds up this summer.
PS- Take some photo classes... Those pics are terrible... J/K
PSS- Oh yeah, I need my autotap back dude! Got SES lights on the ZR2 I need to figure out.
PSSS- I think I still have my stock TA if you want it.
BS!
BS!
