Help me pick new gears, 3.90 or 3.73
Ok I currently have 400RWHP and 4.11s in my nine inch and I am ready to change gears. First off, I dont race and rarely ever go to the strip, the car is mainly a fun hotrod and thats all.
The prime complaint I have is that my 1st gear (T56) is useless if you just ease out and floor it, the tires just light up and on occasion nail the rev limiter. Also I have larger diameter 285/40/17 firehawk dual oval tires which are a very quality street tire.
So what to do, go to 3.90 or 3.73 gears? Ultimately I want a gear that allows 1st gear to hook 90% or so but I dont want to bog things down needlessly. I am concerned that going to 3.90s might not meet my needs so I am looking for others opinions.
Thoughts?
Thoughts?
Other than 1st how do you like the 4.11s? If you like how they pull with your cam through the other gears, what about DRs? I keep hearing from my buddies at work how well they hook up. I don't think the 3.90s will help you out much in first. I guess if I were you I'd look at the f-body.org gear calculator with an eye twards the 3.73s.
I make around the same hp as you , and have 4.10's as well, and love them! IMO you will still have the same problem with 3.73's on a street tire. Get your self a drag radial and you will love your 4.11's again
After looking at your dyno graph 3.90 will suit your needs the best with your car being a vert. You still need a bit more gear to make up for the extra weight of your car.
4.10's kinda suck for these cars.....just a bit over the top. I've had them both and had to make the change to get threw the 1/4. 4.10 to 3.90 is a very noticeable difference.
I have experience with 3.42's, 3.90's and 4.10's. The primary problem here isn't the rear; it's your tires.
Tried out a few different R compound tires (used both drag radials and road race R comps) over the years and they resulted in a substantial improvement in traction on dry pavement. Of all of the mods I've done (with the exception of N2O) upgrading to a tire that will actually get traction was by far one of the best to date.
All that being said, if it isn't practical to go to an R comp tire on your car, then the 3.73's would be easier to handle than the 4.10's (however I'm still not sure it's going to be enough to do the trick).
