Driveshaft length??.. 9" I----?----I 4l80e
Who out there is running a 4l80e and 9"? What lenght driveshaft are you using? Where did you get your yoke from? Car is a 1999 Trans Am. Thanks for the help
just take the time to squeeze under the car and measure it. I ended up having to do this in bad weather as all my other toys that can get stolen easily are in the garage. My measurements with the 4L80 and the stock 10 bolt was the same as what Bob has for his driveshafts. I haven't tried it yet as I am waiting on my center section to get finished...still. Oh yeh make sure you count the splines of the trans tail shaft and see if it is threaded and be sure that you have the car sitting in the air as it would on the ground to get the correct measurements.
