1350-1310 u joint for 10 bolt
I need a conversion u joint that will fit a 1350 drive shaft and a stock gm 10bolt
Stock gm 10 bolt is a 1310 , I bought a moog conversion u joint 1350-1350 and it fit good on the driveshaft (1350) but has too much up and down slack on the drive shaft .
The 1310 part is shorter than the gm 1310 u joint end .
Does anyone knw the correct conversion u joint ?
1350 axis length is 3.622"
1310 axis length is 3.218"
So the 1310 side is actually shorter . Can anyone help me out ?
Thanks
Also my drive shaft only has about 1/4 " of slack on the yolk . Is this not enought ? What's Ideal ? Will I have any issues running it ?
Thanks again !!
Thanks
Thanks again !!
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
This is a re-post - hope it helps
For clarification - for a stock driveshaft with the Moser 12 bolt 1350 yoke:
This is a 3R or 1344 to 1350 conversion.
Moser offers the Neapco 2-1153 U-Joint
The following parts will also fit, (and likely others)
NAPA 447
Moog 447
Precision 447
Hope this helps the folks out there with the stock d/s and 1350 yoke.
Regards,
Darden
PS I found the Moog 447 at Advance Auto for 29.00 or so. About the best price I have found.
NAPA 447
Moog 447
Precision 447
Regards,
Darden
