New 8.8 build hiltsy mount , racecraft brackets.
Made a little progress on the new 8.8 build .... finally. Explorer 8.8 , explorer axle tubes , narrowed 3.5 each side from stock f body , car is mini tubbed. 31 spline locker and axles. Using explorer disc brakes , 15x10 3.5 bs billet specialties. Car currently has an 8.8 just making a nicer , stronger one using the hiltsy mount.
Mig the bracket together,then I used arc welder with nickle rod to weld the bracket to the housing , pre heating with a torch and post cooling the housing. They sell nickle mig wire but its crazy expensive .
Thanks , but I didn't design them bought them from www.racecraft.com . They are for a 9 inch 3 or 3.25 inch tubes. They are really nice and around $235 ....
I narrowed the long side and I'm using two short side 8.8 explorer axles. I will eventually weld on 9 inch ends and have axles built maybe 35 spline with spool. Maybe going turbo and giving up the nitrous set up.
How wide is yours backing plate to backing plate? I run 15 x 10 3.5 bs wheels tuck a 275 60 15 mt pretty easy room for a 325... I ran same set up last year went 1.5 & 1.6 60 ft on same set up , just liked your mount so much I decided to build a better 8.8 with it.
Nice 60'. Is your car M6 or auto? Do you run at Cedar Falls?
That sucks , would of saved a few dollars. I have tons of room , I bought narrow offset lower control arms but didn't really need them. Did you have to order custom wheels? My car was a M6 its now th400 4k stall transbrake. Heads,cam,nitrous ls1. Ive always just gone to Eddyville raceway,but would love to try Cederfalls.
I made my own LCAs and moved them inboard about 1 1/2", the 345s tuck in nicely. I used Corvette Spyder 19 x 12 knock-off wheels and they were relatively cheap. I went to Cedar Falls years ago when I had my old Super Gas Firebird. I recall it was a nice track but the shut down was really short for a 9 sec. car LOL.
We may have to meet up at cederfalls sometime.
Thats if my turd ever gets finished.lol I may need another mount from you , my buddy wants to build a 8.8 out of my junk collection.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
