ABS, and TCS reluctor rings. HELP
Alright I have 1996 Z28 Camaro. It has ABS and Traction Control. I pulled the axles out and they are mix matched and they are not stock. I think one of them is causing a vibration that ruined my wheel bearing on the pass side. Heres the deal its a 4 channel and I NEED THE RELUCTOR RINGS. Because they are two different sizes and making my abs and traction control freak out. I cant find them anywhere. I can find the center reluctor on the carrier. But I need the two small ones that go on the ends of the axles!! HELP I need a part # or something.
Gonna have to buy a whole axle on the used market to get the wheel. Yes you can swap in non-wheeled axles and there will be no issues except abs and TCS won't work.
