Driveshaft install
Old Jul 28, 2014 | 02:37 PM
2QuikTA's Avatar
Default Driveshaft install
So this spring/summer I finally got around to putting the 9" in. I'm by no means a mechanic, but I do my best to try and do things on my own. I really wish I just paid to have the rear installed, but I was replacing the fuel pump while the rear was off. Nothing seems to just slide into place and bolt up[ like it's supposed to....most due probably to installer inexperience. So I finally have it all in with the final piece waiting to go in.....the driveshaft.
It's hard to get a straight angle into the trans because the driveshaft angles up and through the safety loop. The driveshaft goes into the trans about an inch, then stops. Even trying to get it back out of the trans I have to tug at it. Everything seems to say the driveshaft should mostly effortlessly slide in, so what am I doing wrong?
Old Jul 28, 2014 | 04:43 PM
Fox408's Avatar
Make sure it's going in the spines.
Usually much easier if you put the trans in gear so the tail shaft won't spin, then wiggle the driveshaft back and forth while pushing in.
Should be distinctive when you feel it slide in.
Old Jul 28, 2014 | 04:52 PM
2QuikTA's Avatar
Right now it's just in park, should I put it drive?
Old Jul 28, 2014 | 06:24 PM
2QuikTA's Avatar
It's hard to get a good straight angle into the trans with the driveshaft being angled up into and through the safety loop.
Old Jul 28, 2014 | 06:50 PM
01ssreda4's Avatar
Loosen the loop, wiggle the shaft, grease the splines (so it slides easier).
01ssreda4's Avatar
Geez that post sounded kind of dirty.
Old Jul 28, 2014 | 07:32 PM
2QuikTA's Avatar
Grease as in regular automotive grease?
Old Jul 28, 2014 | 08:24 PM
01ssreda4's Avatar
Or trans fluid or anti-seize.
Old Jul 28, 2014 | 10:41 PM
Fox408's Avatar
I've always used the grease for input spines (during clutch install) but I imagine most will work.
You don't need much.
