Rear end wine!!!! Help
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I would think a cf shaft would be near silent....but there is still the torque arm to carry noise. I almost got a cf shaft for this reason but its massive size (3.750in) would have been real close to the e-brake bracket in the tunnel.
I have NEVER had any whine sound from the rear end at all. The gears are extremely quiet.
ProGear is a rear end gear only shop located in San Diego, that's there entire business, they do not do oil changes, sell candy, or wash cars.
My point? "Take your vehicle into the proper professionals to do the work.
When the rear end was initially inspected, the carrier bearings and the axle bearings did not need to be replaced, so in my case the ring and pinion were replaced. I did have the carrier bearing caps "studded" and had them install a "T/A girdle".
The ring and pinion box had the name "Timken" on it, and the gears were manufactured in the United States, ProGear let me know that they do not carry foreign ring and pinion sets, and they shy away from installing them.
I do have an aftermarket adjustable torque arm (BMR) so I do not know if this helps keep things "quiet" I also have the aluminum driveshaft. They reset the pinion angle to "0", and at least for me, all has been well for the last 13 years (knock wood).
The rear end gears were "cryod" for an additional $50, for added strength, and removal of contaminants present in the gear set.
Sorry for any confusion that my original post may have caused.
is coupled / radiated. Hard to say with something that
only happens at speed. But you could try things like
spraying the pumpkin and axle tubes with some sort of
sound deadening (maybe wrap them with some towels and
zip-ties, and road test first, to see about that). Things
like hose-mod will increase cabin coupling. Maybe add a
little "donut" between the lower perch and the springs,
to take some of the edge off. Used to see these on old
cars, did not find any on mine. Definitely would help
keep the springs from ringing and transmitting to the
upper perch. Might look at damping the Panhard and
torque arm tubes somehow, too. Maybe just find or
drill an open hole and squirt some of that expanding
foam down them. If experimenting shows any value.
A heavier grade differential oil might quiet things down
some, if it's tooth / setup related whine.
It was probably an AAM gearset, or one of the few others still made here in '01.
what causes the noise?
how come the noise was not present on my oem 10 bolt in my 2002 ss until after a leaky pinion seal change by the dealer at around 10k miles? when i got to 60k miles about 10 years later is when it started howling.
the s60 i put in last year howled from the get go. had the R&P replaced, started off a little quieter but after ~2000 miles it's as loud as before if not worse. 3.73 ratio, ******* annoying at 55-60 mph.
my 2006 gmc 2500HD with the 11.5" AAM axle with I think 90k miles on it is quiet.
what is different then with "aftermarket" rear ends?
why can't they make them and set them up as good as oem rear ends and be quiet?
http://www.geartechnology.com/subjects/gear_noise
