build a 10 bolt
Unfortunately, you can't build a 10 bolt strong enough to take the kind of HP you're talking about, especially in an M6... unless you NEVER, EVER under any circumstances launch it. That means no sticky tires (and 450rwhp on street tires, you won't get traction at all through the first 3 gears, so you wouldn't be able to race effectively anyhow from a dig)... basically no drag radials, no ET streets. If you just idle away from stoplights and never race at the track, you'd be fine. But then, what would be the point of all the HP?
Honestly, with the amount of rwhp you're talking about on an M6, you absolutely have to invest in a 12 bolt or 9". That is unless you enjoy throwing your money away on a rear end that can't be made strong enough for 450rwhp.
I agree..
other points. if you are planning to keep the 3.42's then your chances
are greater than with 4.10's under power.
another option is an 8.8 ..choice is yours......
And what's the point of 450 rwhp if you never launch it hard? With that much hp, it is wise to invest in at least a 12 bolt if not a 9 inch. Not only that, but if you're making 450 peak rwhp, I'm betting the power band will be something like 2000-6500 rpms or higher, and you absolutely will need a higher gear ratio so car doesn't take forever to reach peak power. Plus with that kind of hp and an M6 you absolutely will need a harder grabbing clutch... here's the real simple formula:
Lots of HP + higher gear ratio + hard grabbing clutch + sticky tires = 10 bolt
or to keep your 10 bolt alive because you insist on using something not strong to hold your new power:
No launches + babying it in the first 3 gears + stock clutch that can't hold that much hp = 10 bolt lives, but wtf fun is it having power you can't use to it's fullest potential?
LPW Support Cover - $150
Eaton Posi - $473
Moser Axles - $225
Richmond Ring & Pinion (W/Install Kit) - $319
Welded Tubes to Center Section - ~$50?
Set-Up - ~$200
Going to be over $1600 when all is said and done, and while it should be able to handle 450 RWHP, you never know.
Moser 9" from Spohn, ~$2200, and you know itll be able to handle pretty much whatever you throw at it
I've blown it up twice, it's not hard to do. The worst was blown spiders, completly twisted off left axle, cracked teeth on ring & pinion and loosened tubes causing leaks at the factor weld points. Some here were at the rental that day.
I've junked that complete unit for a third time started with an 02 unit and built a bullet proof street 10 bolt while waiting to get my 12 bolt in so I can return to the track.
Save for or look for a deal on a 12 bolt, trust us!
Strange custom cut axles,
Auburn posi,
Auburn gears,
Gridle w/ stud kit.
I had to do this to one of my 10-bolts, back before 12-bolts came out and the Dana was the only rear out there. Didn't have the money for one of those at the time.
It never broke, had around 100K miles on a 3rd. gen Z that was heavily modded.
Hope this helps.
Will
GM for putting a 10-bolt in a muscle car.
