Couple of questions on the Ford 8.8?
Hey guys I am looking to upgrade the Rearend Very soon here but cannot make up my mind on a 12Bolt, 9", or the 8.8 Rear. I have been told the 8.8 is a very strong piece so I am thinking of going with that, but I have a few questions that I hope you could help me out with.
1st- How much RWHP will the 8.8 with 4.11s Take away over my 10bolt with 3.42s?
2nd-How much heavier is the 8.8 VS. my 10Bolt?
3rd-Will the 8.8 take 5,000RPM launches on slicks? I am running a Spec stage 3 clutch the X-Pad, and I only go to the track 3 or 4 times a year also.
I only have bolt ons for this year, and plan on doing heads and cam sometime in the fall. I hope you can answer my questions thanks a lot
Dan
Dan
from what ive read the 8.8 weighs like 10 lbs more, and it will take about all the abuse you can throw at it. not sure on the power zap though. like 10 or 15 at the most would be my guess.
I would run a 12 bolt for a car that rarely sees the track, and a 9" for a car that sees a lot of track abuse.
i just started looking into a new rear end and can get a 8.8 off a mustang for pretty cheap. I was wondering if it is a pretty direct swap or do you have to do a lot of modification? thanks
Mustangs use a pretty different setup than the f-bodies. They use both upper and lower control arms rather than a torque arm with lower control arms. You would only be able to use the center section with grafted on f-body axle tubes....which is what Extreme Chassis does.
