02 SLP Rear Help
the tone ring fits auburn,torsen,& eaton.
The guy I'm buying the rear off of must not know what he has and really has a 3 channel because I don't see any sensors or tone wheel. Do you?
http://scranton.craigslist.org/pts/4952897535.html
'I don't see a tone ring for the abs like my auburn has'
if your auburn has a tone ring on it,it's a 3 channel rear.
the rear in the ad shows a 'thick' 4.10 ring gear mounted on a 2 series carrier and no tone ring which would indicate a 4 channel.
3 channel is a tone ring pressed onto the carrier,4 channel is a tone ring pressed onto the end of each axle behind the wheel stud flange.
does your service parts identification(RPO) sticker show a NW9 ?
4 channel rings are on axles
Going from 3.42s' to 4.10s' will require computer adjustment to correct speedometer and odometer.
