How to identify your drive shaft?
I have a 1998 trans am with so much changed out that I doubt the drive shaft is original but how do I tell? The only thing I know is that it is a 3". I asked the guy I bought it from and he doesn't know. Any help here would be great.
I got some pics, looks like a spicer can't read all the numbers on it though. Also looks like I need another cap, one was missing about half of the bar bearings. So is spicer factory original? How can I tell if it's steel or not? It wasn't crazy heavy but not light and I didn't pull the yoke out cause I didn't want to lose any trans fluid.
That driveshaft or the u joints dont look stock. Why? Because where the caps are would be a hole with plastic sticking out. They used melted plastic retainers on the stock u joints, which you dont have based on the pics.
We succeeded that point fella. Thats not an aluminum ear, its steel or chromoly and it doesnt have the hole in it for plastic injection. Try to keep up next time mmmk?
IF Spicer still makes the conversion u joint you need (you do still have a factory GM 3R rear pinion yoke {made by Saginaw, I beleive?}, correct??), I would get that.
If not, the Moogs, Precision HEAVY DUTY (stay away from their standard stuff), and Neapco BRUTE FORCE (again, stay clear of their standard crap) are decent.
No, I have a strange 12 bolt. I went with a summit racing 1350 u joint with grease fittings. It was a pain to press out but I got it done. The ride feels smooth but I need to figure out how to set the pinion angle. I have an angle finder and a bmr torque arm but how do I level the car on jack stands? Is there a place on the frame that is level to the ground so I can make sure I'm level?
I need to make a thread on correcting driveline angles for vibration! Such a pain in the butt explaining it every time with no pictures. I will work on that for ya bud....
