Need help with differential install
I was looking at the differential and I noticed there is a small amount of backlash in between the helical gears. Is that normal?
Did you have any backlash related problems between side gears and axle shafts?
I was about to go this route about a year ago and ended up rebuilding my EATON 12 bolt POSI originally supplied by Strange.
I used the metal clutch discs instead of the original carbon fibre and replaced the spider and side gears as well as the spider gear shaft.
Works very well now.
Better drag race launch lock up??
Supposedly better wear/strength?
Do these 'chatter' more than the carbon ones did, given the same amount (and brand) of limited slip friction modifier?
