Stall or gear swap first? For a DD.....opinions welcome
I have a set of 3.42 motive gears laying around but Im liking the idea of a stall first. Ill be doing both at some point.
Im considering a cam install within the next 3-5 months (after I install either the gears or stall). Im looking at a 4000 Circle D or Yank Converter for my Automatic. 99 Camaro
Looking at your past posts,you put a post looking for a used convertor. Not recommended,no telling what kind/how much crap is in it,no matter what the 'seller' says. Enough crap could take out the tranny. You take your chances with a used one.
A cam would benefit from a 3600-4000 stall,AND a good one from Yank,CircleD,or equivalent.
Stall first !!!
What are your rear gears,2.73(GU2) or 3.23(GU5) ? A car with 2.73s' would benefit from a change to 3.42s',a car with 3.23s' don't waste the effort/time/expense to change to 3.42s'. 3.23s' changed to 3.73s' would be a worthwhile change but after driving with a good stall,you'd probably disregard a gear change.
If the cover is not leaking,why bother to touch it. How many miles on the car ?
Stall first !!!
LS1Tech Administrator
Received 1,493 Likes
I wouldn't even think of gears prior to doing a stall swap on a 4L60E/LS1 application. Ever. DD, weekend toy, track mule, doesn't matter IMO.
The above posts by FirstYrLS1Z contain excellent advice, I'd recommend following it.
I'm so predictable!
I did the 3.42's first and liked it, then a 278 Circle D 3200 and love it. I would do the gears first, then a good converter which you will want to do. Tune it one time and your good to go. Just my opinion.
Definitely do the converter first, especially if money only allows for one. You may discover that the gears are totally unnecessary for you at that point (saving you some install cash.) If it feels a bit too loose for your taste, you can always do the gears later.
I need a new tune right now from all the bolt ons but figured Id wait until the gears or stall upgrade
Here's a good recent thread where this was touched on near the end:
https://ls1tech.com/forums/automatic...l#post19469504
