Pinon Angle vibration
I had slowly acquired a vibration at 75 mph then it got worse at 65 mph over a short amount of time. I figured out the rear upper adjustable control arms had come loose. I readjusted the angle and things got better. But i was still vibrating at 80 mph. So I used a angle gauge (which I should have done to begin with) to figure out that the rear was 9 degrees up and the Trans was 6 degrees down. I can only go 4 degrees down on the trans before it hits the floor at 3.5 degrees. I have read that the angles should be at 2 degrees in parallel. Should my setup be ok if I used 4 or 4.5 degrees instead. I have read that my yoke can handle about 30 degrees and is used by the off-road community a lot. Or should I yank the trans and make some more room by hammering some dimples into my floor?
Remember you are shooting for the 2nd pic, equal or equal but opposite angles.
Measure Angle A and Angle B on the caps that stay flat.
What I cant get over is when I set everything up the first time, I had no idea about pinion and trans yoke angles and somehow I set it up pretty good on chance as I could hit 90 mph and not feel any vibrations. Beginners luck.
