Driveshaft Question
I have a 2002 z28 with a 4l60e and S60 rear end. When I did the S60 swap I ordered an all chromoly driveshaft from MWC. I am in the midst of putting together parts list for my TH400 swap. I am aware that a new trans yoke will be needed, but my question here is, is there a yoke that I can purchase that will allow the use of my current driveshaft or will I need to have a new driveshaft made? I am under the impression that the driveshaft I am currently running will be too short.
Any help is appreciated. Thank you.
MWC you'll be getting a phone call in about a week. I'm going to upgrade to your LCA's and Panhard, switch my torque arm to your true dual x pipe short arm setup, and get my th400 swap crossmember from you. Once I finish the swap I'll call back with dimensions so we can order another driveshaft too.
I bought a new one from Strange Engineering since they're here locally.
