Making a crown vic 8.8 work
Old 06-19-2018, 11:57 PM
adrian650's Avatar
Default Making a crown vic 8.8 work
Hey new to the forums but been lurking around for some time. I currently have a 8.8 out of a Crown Vic disassembled. I was wondering if any one could help and guide me in the right direction for a torque arm mount. Reason i chose this rear end is because of its length being similar to the stock f body rear end. Will a hiltsy torque arm mount work? Anyone out there have a Crown Vic rear in their car that can help? Sorry i know this topic has been beat to death but i just can't find an answer after months of searching.
Old 06-20-2018, 08:15 AM
80/TA/LT1's Avatar
Hiltsy mount will work great
Old 06-20-2018, 02:20 PM
adrian650's Avatar
Have you tried it and had success?
Old 06-20-2018, 02:57 PM
80/TA/LT1's Avatar
My rear is from an explorer, my buddy's is from a crown Vic, both are working fine with the hiltsy mount
Old 06-20-2018, 04:03 PM
adrian650's Avatar
What did your buddy do about the 3 bolt holes that are missing on the passenger side of his rear end?
Old 06-20-2018, 04:24 PM
80/TA/LT1's Avatar
Didn't use them just clamped and welded
Old 06-25-2018, 07:27 PM
Cole Train's Avatar
my 8.8 is from an Explorer. 3.73's and now upgraded with Ford Racing carbon clutch packs. I had a fabricator called TNT from OK do my fabrication. i built and set it up after i got it back
Old 07-05-2018, 08:09 PM
adrian650's Avatar
what did you do to relocate the fill hole since the hiltsy mount will block the current fill hole ?
Old 12-03-2018, 06:32 PM
enyo's Avatar
Default Cover
Get a ford mustang cover that has fill, drain, and vent ports on ebay.
Quick Reply: Making a crown vic 8.8 work
