noise in rear
But could also be your positrac. An auburn positrac needs additive every so often. A torsen does not. So could be a binding clutch in the positrac if it's an Auburn. Cheapest solution is to add the additive first to see if that corrects the issue. It probably needs it anyway. If not then pinion bearings.
https://www.summitracing.com/search/...p-oil-additive
Assuming of course that shocks, panhard bar, etc are all connected and/or not loose or broken
Torsens aren't rebuildable, you can disassemble it but a special fixture is needed for reassembly.
