Who's got the best deal on ford 9 in?
Old 08-22-2020 | 12:48 PM
jimmyg's Avatar
Default Who's got the best deal on ford 9 in?
Need a ford 9 in for g body. LAst rear ended I got off of Carl at central racing parts . I don't think he owns it anymore . I wanna shop around , get the best deal .
Old 08-25-2020 | 03:24 AM
showdog75's Avatar
Quick Performance
Old 08-25-2020 | 11:44 AM
jimmyg's Avatar
I need one for a g body . 83 cutlass
Old 08-25-2020 | 03:56 PM
MidwestChassis2's Avatar
Strange has a couple options do you want a true fab housing or okay with stamped?
Old 08-25-2020 | 08:19 PM
jimmyg's Avatar
The following users liked this post:
mikedamageinc (08-26-2020)
Old 08-25-2020 | 08:43 PM
jimmyg's Avatar
Car has an ly6/ whipple 2.9 / 4l85. Has an s60 in it now , but pinion sits a little high . Can’t get a decent u joint angle . It’s just out of spec. Vibrates on hyway . I would like a stamped housing , powder coated. 35 spline , s trac, 3.40 alum center section ( if it will handle hp) big ford ends ,with wilwood brakes w/ parking brake , red calipers . Car is lowered 2in . Ride tech coil overs. I’ve tried all sorts of things to get a better angle . I was told the pinion on a ford 9 is an inch lower than a Dana 60. It would solve all my problems . Also the highest gear you can get in an s60 is 3.54. This is mainly a street car with trips to the track . It revs a little on hyway with a 26 in tire . Also it runs out of gear in 3rd at about 1000 ft mark . 130mph I have to shift into 4th at the track. I originally wanted 3.25 but i don’t want to lose too much acceleration. I fig 3.40 would be a good compromise.
I also don’t need any spring perches. Just upper and lower control arm brackets , as coilover bracket attaches to lower control arm bracket . Unless there is a better way that’s not gonna cost me a bunch of loot .
Old 08-26-2020 | 08:53 AM
mikedamageinc's Avatar
Quick Performance for sure, I'm waiting on mine from them and was like a grand less than everyone else. Nice looking ride btw
Old 08-26-2020 | 03:59 PM
There is always a cheaper price option out there but with cheaper rearend cost it means cheaper product.
Strange G-Body Housing Part Number: HF9GGME $835.00
Strange 35 spl Alloy Axles Part Number: P3502 $439.00
Strange S Series Nodular Case W/ Ring & Pinion and Grip pro Differential: $1250.00
Powder Coating $159.00
Can be assembled also would need to know brakes.
For a street car you don't want the aluminum light weight case as you will here more gear noise. Now if you mean the HD pro that is a different situation.
Old 08-26-2020 | 06:49 PM
jimmyg's Avatar
I want the s trac . Brakes are B2708wc-red or the 11 in wilwood as long as the calipers are red .what about pinion support? Car is 650-700 rwhp . How much more is the HD pro alum case? I wonder what the weight difference is , if it’s even worth it . I’ll try to give you a call tomorrow . If you can get me a good deal, I’ll order it .
Old 08-27-2020 | 09:07 AM
Best is to email sales@midwestchassis.com and we can put a few different options together.
Old 08-27-2020 | 09:25 PM
How does your housing differ from the QP version?
Old 08-28-2020 | 09:14 AM
What is quoted above is a Strange housing however our housings are a fabricated housing, we also have in the works a fabricated housing for the G-Body platform.
Quick Reply: Who's got the best deal on ford 9 in?
