Contact pattern check
Old Dec 11, 2020 | 10:41 PM
Karlw's Avatar
Default Contact pattern check
GM 8.5 10 bolt (circa '79)
swapped in a series 3 carrier with a set of US Gear 3.55 (01-885355) and new all new bearings
US Gear calls for a backlash of 8-12 thou
original pinion spacer .039" put me right at the pinion depth of 2.591" (wasn't that convenient)
first set is with the Pinion spacer at .039" and a backlash of .009"
drive
coast
Old Dec 11, 2020 | 10:43 PM
Karlw's Avatar
Second set is with the pinion spacer still at .039" and backlash at .011"
drive
coast
Old Dec 11, 2020 | 10:44 PM
Karlw's Avatar
Third set changed the pinion shim to .034" and backlash was at .012"
drive
coast
Old Dec 11, 2020 | 10:45 PM
Karlw's Avatar
Fourth set I moved the pinion shim to .044" and the backlash was .010"
drive
coast
Old Dec 11, 2020 | 10:49 PM
Karlw's Avatar
It looks to me like the .039" pinion shim is a winner, but both sides still run a bit biased toward the toe, especially the coast. I'm thinking I should shim the carrier for a .010" backlash with the .039" pinion shim and send it. Anyone with experience doing this think I should do something different?
Old Dec 18, 2020 | 10:27 PM
Karlw's Avatar
Bump. There's got to be a few people left on this board that know this stuff.
Old Dec 19, 2020 | 07:46 AM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
Agree with your post #5, .039 looks best and agree with the .010 and run it. Both the .009 and .011 have nice wide contact areas for the drive side. The drive side for me is more important as it would see higher torque from powertrain and since you're changing gear set for better acceleration ( I assume), the largest contact pattern (area) would provide least wear.
For me I rather have least amount of wear and slight noise vs no noise and a gear set that'll wear out prematurely.
Follow recommended break-in procedure and then sometime in the future do a drain/inspection to look at the resulting established 'shiny' pattern.
Bigger enlargeable pictures would have been better for evaluating.
Old Dec 19, 2020 | 04:12 PM
Karlw's Avatar
When I read this reply, I thought "WTH, I did post big pictures". Well, I don't know what happened, but there where better pics there when I posted. They should be fixed now, maybe.
Old Dec 19, 2020 | 04:41 PM
The better bigger pics confirm the .039.
