Trutrac failure?
Read some reviews past few days. Great for 4wd applications. Apparently, they don't like hp. So getting a new standard style Eaton LSD. This is a 3 event car so it's not getting a spool.
I just can't win on any part I buy no matter how much I pay. And this car doesn't even make much hp.
The fact that it whined from day one is an indication that something was wrong from the get-go. Maybe they didn't set it up correctly. Also, did you use synthetic gear or a friction reducer? Eaton recommends against that (only mineral oil). My understanding is, the unit will not work properly (needs friction to transfer the power to the other wheel). However, I wonder under extreme conditions if it can cause a durability issue. But again, you had a whining, and I'd be surprised if that came from using a friction modifier.
So far everything I have bought for his car has had issues. Clutches, transmissions, driveshaft, rear diff, some suspension parts. The only thing that has not had one issue is the engine and coilover shocks. I did all engine machining, building, porting and full assembly myself. Its just a little 408. I can't win.
New one be here tomorrow.
What really sucks is you can't just get parts for it. Housing and small gears are fine. I just need the 2 side gears. Eaton doesn't sell parts. Just the whole unit.
daily driver. 15 miles of turns each way to work. Ran the recommended
lube. The helical gears surfaces spalled off and it ate itself to death. Only
thing that seemed to be a possibility looking at it when it was out was they
don't like housing flex at all. You could see the wear marks in teh spiders where
the housing must have had some bend in it.
Went to an ARB and 200 K later its still fine(same housing),,.
I've often wondered why folks don't run ARB's for split duty cars..
Yea they are an extra 3 to 400 bucks installed but from what I've seen its
almost always the axles tor the pinion that give up before the ARB.
Takes almost no air volume to run one, actually have one in the front of the jeep too in a Dana 30.
I have their small compressor work like a champ, and you know you wanted a source for your air throttle anyway! LOL
Like mentioned above a S60 or a true fabricated nine inch is the only way to go for these vehicles. If the nine inch uses a bracket on bracket system I would stay away from those as well as they create a torque arm fitment issue with the floor.
https://shop.brutespeed.com/Brute-Sp...nformation.htm
The 12 bolt rears that are available for these cars is a step in the right direction. The 12 bolts are well known for being a stout rear that was a factory option back in the day in many performance cars. You can have a 12 bolt in an early Chevelle, Nova, Camaro, etc, and beat the snot out of it and not hurt anything. Put a 12 bolt into a late model f body that uses a torque arm, make a couple 4000 to 5000 rpm launches at the dragstrip, and I can just about guarantee you'll have a lot more gear noise on the way home. The torque arm seems to distort the housing on the 12 bolts, and it seems to happen to all the brands of 12 bolt rears. This does not happen to the 9 inch rears, and there is no price difference between the 12 bolt and nine inch rears. As the horsepower in our engines keep escalating, most people these days go straight to the nine inch rear. The 9-inch has an internal rear-pinion support that also supports the gear end of the pinion to limit gear deflection under high torque loads. This seems to be the major reason why the 9 inch doesn't start whining after high rpm clutch dumps, when the 12 bolt will pick up noise. The 9-inch locates its pinion gear lower on the ring gear to improve tooth contact, better the 12 bolt does. The 9-inch also has a 0.125-inch larger ring-gear diameter and internal pinion support than the 12 bolt. The 9-inch rear end, originally offered in 1957-1987 Ford cars and light trucks, has been a mainstay in drag racing for over 50 years. Its beefy 9-inch ring gear proved to be an effective alternative to the 8-3/4 Mopar and GM 12-bolt (8.875-inch diameter ring gear) housings of the era. The Ford’s removable carrier design made it easy to swap gear sets, and the aftermarket responded by offering over two dozen ratios between 3.00 and 6.50:1.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
