Pattern check on 8.6 10 bolt
Old Jun 11, 2025 | 03:30 PM
Novapat67's Avatar
This is to swap to 4.10 gears in an 8.6 10 bolt, from a 2003 S10 with 3.42 gears, in a 1965 Nova 4dr, with a 4l80e. Its a unique combo haha.
A few people on another forum thought it needed a thinner pinion shim. They also thought I would have nothing but problems with a gearset from Quick Performance. I think I am going to try it like it is and see. Thanks
Old Jun 21, 2025 | 02:49 PM
Novapat67's Avatar
Ok, I figured I would try one more combo before I put the final bearings on the pinion. This was with a .030 pinion shim (instead of a 0.037 shim), 0.006 backlash, and 16 in/lb of preload on the pinion. Do these look better?
Old Jun 21, 2025 | 04:03 PM
FirstYrLS1Z's Avatar
Active Streak: 30 Days
No, doesn't look better, looks worse.
Old Jun 21, 2025 | 06:02 PM
Novapat67's Avatar
Ok, I might try a 0.033 shim and if it doesn't look better, I'll just go with the 0.037 shim. Thanks for your help!
The reason I tried a 0.030 was because it kinda looked like it was a hard line at the root on the drive side.
Old Jun 24, 2025 | 06:03 PM
Novapat67's Avatar
Alright, i think I am going to run it with this setup. This is with 0.008 backlash and a 0.033 pinion shim. Thanks for all the help!
Old Sep 28, 2025 | 06:36 PM
Michael96's Avatar
What do you fellas think of this pattern? This is a 8.5 inch with 2cut gears...
