Pattern check on 8.6 10 bolt
I always shoot for the tighter of the lash range. Let's say .006" as example, when the gearset is broken in properly and some decent non-abusive miles are put on it, that .006 will probably open up to .008 since the machined surfaces of the teeth are wearing together to eliminate all those imperceptable machining marks made during manufacture.
The times when a tighter setting shows a unacceptable pattern, then I will setup up for the middle range.
Look at these old threads for reading pattern and marking paint thickness.
https://ls1tech.com/forums/gears-axl...r-pattern.html
https://ls1tech.com/forums/gears-axl...ern-check.html
The true pattern showing of the ghosts looks really good., nice wide center contact. What was the lash for that ?
If I was setting that up and those were the patterns, I'd be running it.
Good luck with the spacer; they can be pretty time consuming, at least for me. I tried one a couple of builds ago, lost patience (I needed to finish that day/ night), and just ended up throwing a crush sleeve in it.
Let us know how it goes.
A spacer has no 'spring' to it, A .0005' wear in of the bearings and preload is gone. a crush sleeve has some 'spring' in the area being crushed.
The bonding agent will be softened and the carbon fiber will fall off the clutches.
Also, if you have time chamfer all of the teeth on ring and pinion to deburr and sharp spots.
