9" center section question
Old Aug 13, 2004 | 01:29 PM
991LE's Avatar
Default 9" center section question
It seems that there are 3 center sections
Stock center section?
Nodular iron center section. Good for street/strip
Aluminum center section. Good for strip.
I have a detroit locker with 4.10 gears and a stock center section. Is this going to hold up on a bolt on/cam 6 speed car or should I get a Nodular iron or Aluminum center section?
TIA
Old Aug 13, 2004 | 01:56 PM
JeffT's Avatar
the stock ford center piece will work fine for you but it's not as strong as the aftermarket pieces offered by Moser or Strange.
Old Aug 13, 2004 | 04:24 PM
991LE's Avatar
I guess the stock center section will be the weak link.
Old Aug 14, 2004 | 12:10 AM
jswhite's Avatar
With a 6-speed I would go with a aftermarket nodular case at the very least. You can get a Strange case for a little over $200.
Old Aug 14, 2004 | 01:18 AM
991LE's Avatar
Is it very hard to move the locker over to the new case, or will I have to pay somebody to set it up?
Old Aug 14, 2004 | 12:11 PM
badpewter-z's Avatar
LS1TECH Sponsor
Aluminum here and street driven regularlly
no problems yet , hopefully it won become an issue, the car sees street and strip what have you read bad bout it for the street?
Old Aug 15, 2004 | 03:46 PM
BTL FED's Avatar
There are also:
Alum Bolt Through Cases
and Magnesion Cases
Check out:
www.markwilliams.com he has all the goodies =0)
Old Aug 15, 2004 | 06:22 PM
991LE's Avatar
The only bad thing I have heard about the aluminum case is that it requires bearing replacement more often if it is driven on the street.
Old Aug 16, 2004 | 01:22 PM
991LE's Avatar
Originally Posted by BTL FED
There are also:
and Magnesion Cases
Check out:
Those are a little pricey!
