How do these compare?
Old Sep 18, 2004 | 10:51 PM
02WS6Bird's Avatar
Default How do these compare?
i will be converting to a T56 from my auto....im thinking...
FLP Extreme Duty (i will be having a 455 stroker after time and dont kno if the Performance Built would handle that power and a high RPM Clutch Dump) Steel Driveshaft and a 12 bolt rear with 4.00+ ratio
now what would be the most streetable...quiet and smoothe rear that uses the TCS and ABS stuff....
4.09 in the SLP 12 bolt?
4.10 in a Moser 12 bolt? if so what type of 12 bolt to get?
Strange 12 bolt? same thing (i.e. ##Spline, or spool or whatever)
(i have little knowelede of rears and hell trannys all together all i kno is that i want a stick i need it durable since i dont wish to replace tranny parts when i install the Stroker putting out near 550 hp and torque) and it will be my daily driver
Old Sep 19, 2004 | 10:51 PM
02WS6Bird's Avatar
any1?
Old Sep 21, 2004 | 06:20 PM
02WS6Bird's Avatar
anybody??????
it would really help...what clutch will work out best
Old Sep 23, 2004 | 09:53 PM
02WS6Bird's Avatar
why isnt some1 answering? PLEASE SOME1 lol
Old Sep 24, 2004 | 07:40 AM
2MuchRiceMakesMeSick's Avatar
Do you have traction control (asr)? If you do I would get the 9" and you should be able to keep all of that. That motor you plan on running will break that 12 bolt if you convert to a M6.
Old Sep 24, 2004 | 04:39 PM
02WS6Bird's Avatar
MTI did it with the stock rear ....and theres PLENTY of people putting these numbers down on ther 12 bolts....
02WS6Bird's Avatar
i do have TCS by the way and would liek to keep it..and this is going to be my daily driver
Old Sep 27, 2004 | 11:18 PM
02WS6Bird's Avatar
anybody ?
02WS6Bird's Avatar
anybody ?
