Help Change A 3 Chanel Car To A 4 Chanel Or Convert A 9 Inch To 3 Chanel
aNYONE OUT THERE KNOW HOW TO MAKE MY CAR A 4 CHANEL CAR OR CONVERT A 9 INCH REAR TO A 3 CHANEL SET UP
PLEASE HELP ASAP
PLEASE HELP ASAP
This is what we need to try. It is a reluctor wheel attached to the pinion shaft at the rearend. The company is Jags That Run. Here is a link to the picture and an explanation:
http://www.jagsthatrun.com/Pages/Par...ctor-Diff.html
PLEASE HELP ASAP
PLEASE HELP ASAP
I've been wondering about the same thing. I am dropping in a 395 LS1 into my 94 3.4 Camaro. I'm in this way too deep to turn around (so please dont tell me not to do it).
I found out the hard way that I have to change out just about everything. I also want to drop a 9" in but dont wqant to lost the ABS. Since I have purchased most of the parts to upgrade to a 99+ LS1 Camaro, I think I can just get the ABS computer and any wiring needed to make it work.
14 Second Truck Club
I saw a ABS kit that bolted in by the pinoin support on a rear end before. I was a externat ring that went on to the yoke with a sensor that attached to a bracket. It looked kinda flimsy though. I will try to find a link.
I guess there are two scenarios:
1. Modifying a 3 channel system to accept a 4 channel rear end (9" or 12 bolt)
2. Modifying the 4 channel rear (machining) into a 3 channel.
Scenario one is the plan that I want to try, because I am already swapping out every friggin thing but the body of the car, so I think it will be easier for me . I just wish I had more details in what needs to be changed (like ABS computer? wiring?)
Scenario two seems easy enough, but requires machining the diff housing and possibly the ring gear. Why isnt Moser, Currie or any other players currently doing this? Is it even possible? Does the 9" ring gear have a larger outer diameter than that of a 10 bolt? If so wouldnt that affect the pulses that the sensor sees? (or does that even matter)
David
David
Originally Posted by ROCNDAV
Are all LS1 based fbodies 4 channel and LT1 based 3 channel? or is ther a crossover year other than 1997/1998 ?
D
D
without = 3 channel
Gilbert
