NEED HELP WITH GEARS for an 02' Z-28
I have an 02' Z-28 and today was the first day i took it to the track.....i ran 14 flats all day....WTF i thought i was suppost to do 13's or somthing....i only have a cutout done and i have 2.73's....is it my gears???
Running 14s In A Ls1 Is Unreal!
CAP THE CUTOUT IT FOR SOUND AND DYNO QUEENS!CHANGE PLUGS TR55-OR TR6.RETRY THAT JUST FOR STARTERS.OUR STOCK 99 WITH 92,000 WENT
13.20'S-13.50'S THEN WE DID ALL THE BOLTONS @FM2W-RACING SHOP
Originally Posted by LS1Maniac
What were your 60 foots? What MPH were you running? We need more info on your car as well. I'm assuming it's an Auto.
Originally Posted by LS1ZGUY
yes it's an auto and my 60 foots were 2.4's and a 2.5 i can't remember but all the runs my mph were 102....
Wrong, a cutout will run ALOT better then the stock exaust and Y pipe.
ALSO THE CAPS LOCKS IS RIGHT ABOVE THE SHIFT KEY ON THE LEFT OF THE KEYBOARD....PRESS IT ONE TIME
Air box, ported MAF, free ram air mod, throttle body bypass mod & cat back.
If you decide to change out your gears go with 3.73. It will make a big difference.
Your 14's i would think are almost a direct result from 2.4 60 foot times. If you have an auto you hsould be able to get those down to around if not lower than 2.0. I have a m6 so im not sure how low you can cut a 60 foot time with the stock converter but im pretty sure you could eventually cut something like a 1.8, as long as you can get traction.
what are your other mods...more info on the car.
also where are you located?
I agree. You should be able to get a 2.0 - 2.1 60 ft w/ stock converter and 2.73's. My car stock w/ lid and single chamber flow went a 13.49 with a 2.29 60 ft. @ 105. The next week at another track I was cutting 2.02 and 2.03 60fts.
we have built several cars with 2.73-3.23-3.42 gears and the more power you make the less gear you need! ours went 13.70-13.80's with gforce 3200 and 3.73's now it runs 12.80's with 3.42's fm2w arms et'st 26x11.50 105-107mph 92,000miles.heads off the wall next almost done porting.308 so far @ .600
