Carrier swap completed!
Anyways, all turned out good. I replaced the broken carrier with a torsen off a ’02 WS6. I just bolted on my stock ring gear on the carrier, and went to town checking for backlash. I didn’t even touch the pinion gear, so I didn’t have to mess with pinion depth, thank goodness. I used a dial gauge I bought from Napa (which cost about $100), and got the backlash set to .008 using the stock shims. I put everything back together, and tested out the new rear. No more popping noise.
A big thanks to HavATampa and WJ SOM SS, I know I couldn’t have done this without your guys help.
You need that gear looking ring attached to the new diff for your ABS sensor to work properly.
I took everything apart, and just lightly tapped the reluctor wheel off with a hammer. I came off in no time, and I just carefully put it on the new carrier by tightening the bolts in a criss cross pattern. Went in just fine. It took me all of about 1 1/2 hours from start to finish. I'll check tomorrow to make sure the ABS INOP light is off, which I know will be though. Thanks guys, happy new year!
WJ
WJ
WJ
