is it time for me to get a drive shaft??
Old Feb 7, 2005 | 05:11 PM
WS6FirebirdTA00's Avatar
Default is it time for me to get a drive shaft??
ok well i am doing heads and cam soon. i have the stock rear end but will be getting a 12 bolt next year. should i get a drive shaft now or should i wait until i get the rear end? i just dont wanna snap it runnin around on the street with the addition of the cam and heads. let me knwo what you guys think
Old Feb 7, 2005 | 07:06 PM
1ScrudeDude's Avatar
M6 or A4? I say you're ok until you get slicks and start hard launching.
Old Feb 7, 2005 | 07:25 PM
bigdsz's Avatar
Forget the 12 bolt with a M6 with cam and heads, 9". If you get a new DS now, which you probably will need after your mods, then you'll need another one when you switch rears.
Old Feb 7, 2005 | 07:30 PM
why do you say forget the 12 bolt? im just worried if i drive around with that power if the stock aluminum one will fail on me if it is run hard. i wont be on slicks or anything until i get a new rear, or should i just get a new DS now? if im gonna have to get a new one anyway, where can i get a HD stock replacement cheap that wont bust on me?
Old Feb 7, 2005 | 07:46 PM
bigdsz's Avatar
Use the search feature in this section and I think that will convince you that you'll kill a 12 bolt with your mods. I just got a 9" a couple of weeks ago because others put the fear of a 12 bolt in me. My Denny's Nitrous came in the mail today. Anything other than stock tires will gernade your rear or DS.
Old Feb 7, 2005 | 07:50 PM
yeah, im just worried about fitment of the 9 inch and making sure everything will work. i want it to function just like the stock rear, with all attachments and all. i dont want to modify much of anything. i have looked this up for a while and im really torn between the two but started to lean toward a 12bolt. how much does a 9 inch run and how was yours goin in? would i be safe on nittos and stock ds? if not ill get a steel one but i dont need the best right now if im gonna sell it in a year, who makes a good one for under 300?
Old Feb 7, 2005 | 08:18 PM
bigdsz's Avatar
Norris Motorsports that does my major installs and dyno tuning has told me for years if I use anything other than stock tires, including DR's, that I will break the rear and or DS. I have lived for a long time without much traction, next week my Mickey Thompson ET Street Radials will be in, can't wait.
Old Feb 7, 2005 | 08:28 PM
well i guess ill start up a new thread on what drive shaft to get by on until i do a rear, thanks for they info
Old Feb 7, 2005 | 10:30 PM
I got mine today! They are made of Super Glue! Those ***** stick to the pavement! I was dumping the clutch on the street at 4000 rpm with 25 cold psi's, and my 413/383 motor bogged! We're going to have to dump this thing at around 5-6k.
Even I am now regretting my *new* 12 bolt, thinking it was going to handle the load. I guess a spool is my only alternative now...
