12 bolt question?
Old Feb 14, 2005 | 02:33 PM
35thls1ss19's Avatar
Default 12 bolt question?
Ok i know this has been asked a hundred times if not more. But anyway i been reading what everyone says and i am stuck..... Stange are put togeather better? But yet some people do not have problems with there moser? So anyway i am wonderign what to get, it is finally tiem to get my rear and i want to do it right. Hopefully next year i will do heads and cam and maybe a little nitrous eventully. I want to keep my abs and i dont want it to break! lol Sp what spline axels, what gears (i was thinking 4.11) what brand and what upgrades you recomend? Thanks!!
Old Feb 14, 2005 | 11:36 PM
ttt no sugestions??
Old Feb 15, 2005 | 01:33 AM
TheBlurLS1's Avatar
That's what she said...
i bought a moser 12 bolt w/ 4.11's. i ordered it from speed inc. fully loaded with 33 spline axles, ta cover, 1350 yolk. it was in my driveway 8 days after it was ordered! i painted it, pressed on the bearings, had my u-joint changed out and threw it all under the car. had it going this past friday.
the 4.11's are awesome, i havent really rhomped it hard yet, because i'm going for overkill on the break-in but i can tell you this, my rear end used to have 3.08 gears (not my fault, in it when i bought it) and going from that to a 4.11 is radical. 2nd gear feels like 1st used to! its going to scream when i can get on it. the rear end itself is DEAD SILENT on the highway, only problem is, that at 70mph (speedo on like 85 lol) the rpm's are at about 2000 and the duals are abit loud. the old setup put 70mph right before when the duals got loud and it was quiet in the car.
the moser unit uses larger housing tubes for the axles and all the welds on mine were TOP KNOTCH. i'm 99% sure they were done by a machine, but if it was a human, he is one with the welder
some people have noisy moser rears, maby mine will after a few hard launches on the 315 nittos, but i'll find that out soon enough. alot of guys get them, and if they whine, you buy a new ring/pinion and have it set-up nicley by a respectable shop. the money you save on buying a moser rather than a strange will cover most of the cost of this (if it is even needed). most people just live with the whine, because NO WHINE is the minority in high performance gear sets.
when you order a moser, you wait for it to come in, then you remove your stock backing plates and slide them over the axles, then slide on the bearings and press them into place. then slide them in the housing. all you really need is a press (i've heard napa will do it for you) to install it. plus you can pickup the part number 447 conversion u-joint while you're there to go from stock driveshaft to 1350 yolk
Old Feb 15, 2005 | 06:57 AM
freakynipples69's Avatar
Would also like to know whether to go with moser or strange.
Old Feb 15, 2005 | 12:40 PM
Technoman64's Avatar
I recently ordered a Moser from Ls1Speed. I have not recieved or installed so I do not have much feedback as of this time. After researching this is the one I decided to go with though. I got the 33-spline axles, heavy duty posi, and TA rear cover also.
Old Feb 15, 2005 | 01:11 PM
Kakarot2569's Avatar
I will be ordering a 12 bolt soon, do we think that the Posi is worth it, I hope to be pushing about 550 to the rear with nitrous, with a sticky tire is the posi in a 12 bolt on short time or should it be ok?
Old Feb 27, 2005 | 12:22 PM
BigSteele's Avatar
ttt, I want to know about the above ? with an M6 car
Old Feb 28, 2005 | 11:45 AM
TheBlurLS1's Avatar
get a 9" w/ a locker or soft locker. the posi will break in a 12 bolt i'm not well informed about the tq capacity for the 12 bolt posi's, might want to do a little research. i have the 33 spline eaton HD in mine.
a 12 bolt w/ a spool is another option, some people dont have a problem driving a spool on the street though.
and BTW - an update of my origional post, i've done quite a few rhomps, launches, full throttle runs, and my rear end is still dead silent. i'm running 85w-140 oil w/ 1 bottle of limited slip additive. i've got around 700 miles on it and i'm going to change the fluid probably sometime this week, should be alot easier with the TA cover
Old Mar 2, 2005 | 01:27 PM
BBQLS1's Avatar
For 12 bolt lockers check out:
http://www.detroittruetrac.com/appspage.htm
Old Mar 2, 2005 | 01:30 PM
BBQLS1's Avatar
Better Yet
http://www.detroitlocker.com/newprod.htm
