Any Tubular K Member owners in here?
Re: Any Tubular K Member owners in here?
I have an ARE chromoly K member and aarms( roadrace version) that MTI is installing when i get all my other work done so i will lettch know how it is in a week or so!
Pa k-member and a-arms, I have not installed them yet but plan to as soon I get my Incon kit, so it could be a while. I am going to install them in my garage. I will be holding the front of the engine up with a engine hoist, the back of the engine I plan to hold up with some adustable jacks. Should not be to hard.
Gary
Gary
LOL... sounds like there are alot of K-member's laying around <img src="images/icons/wink.gif" border="0">
I have a Anthony Jones Engineering Kmember and arms setting in my living room <img src="images/icons/wink.gif" border="0"> . Do to my work schedule it will be installed in about three weeks.
D(irecto)r Pepper
I know of the extra clearance gained.
But i am still curious of the ACTUAL weight savings. Has any "user" verified this amount? <img src="images/icons/confused.gif" border="0">
Hey John, for some reason the ARE K-member combo is not as light as they claim.... I think they have been contacted on that issue.. BUT the PA Performance K-member and A-arms are VERY noticably light. Larry (PAIN) just got his PA set. They are at MTI or just call him. He will tell you.. VERY LIGHT!!
Anthony <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
I have the PA chromoly A-arms and crossmember. I don't remember the actual weights now but I remember saying that while the weight savings weren't quite as much as they claimed, it was pretty close. Those factory pieces areHEAVY!!!
I believe the total weight savings on the PA pieces is 44 pounds if you get the version that doesnt accept the front swaybar. I dont know if this figure includes the weight reduction of the stock swaybar as well.
Hope this helps,
Chris
Hope this helps,
Chris
Big John,save your money!!
The weight is in the factory A-Arms and the factort power rack..NOT the K-Member...
Just get a set of PA A-Arms and a Madman Manual Rack..Madman is a great guy and I've talked to him in length about it..Thats what I will do down the road..
JS
JS
you need some equipment to install a k-member..
the motor is mounted on the k-member
i don't have an aftermarket K, but i figured that might help you make a decision on the 'ease of installation'.. i talked to my collision repair man about installing one, and after he explained to me how to take it all apart, it didn't sound like 30#'s would be worth that much work
The PA chromoly is 25.5 lbs lighter than the stock piece. (K-member only, weighed difference with a digital scale) Mine was installed with a floor jack (no lift)
Yes in Chromolly u save 25lbs but I would NOT run a chromolly Kmember on the street
U will need to have ALL your welds recheck once a yr and make sure the CM didnt crack.Steel is the way to go IMO.
Terry u save 14lbs changing the A-Arms
But u save 30+ changing the Power Rack to a Madman rack WHICH bolts right into a STOCK Kmember
So if u take out the Aarms and go to a man rack u save 30 plus about 4 for the pump/lines plus 14 for the Aarms
Thats the way to go and thats what I'll do
But I will run STEEL Aarms...
JS
JS
JS
JS
Take my word for it, that manual rack is not that much of a savings, and not worth it. My steel kmember (not installed yet) comes in around 18#, I hear the stock kmember is almost 50#.
I could be wrong but that doesnt happen to often <img src="images/icons/wink.gif" border="0">
Terry u were smart for buying steel..
Lets wait and see what happens to these CM guys after a yr...Can u say reweld,cracks and alot of BS.....
Both pieces would be the best
A Kemeber/aarams and a rack...
Doesnt really matter Terry,with your 375CI,S2X heads and MMS234567879-V12345 Cam have me outmatched..
My car is a tank thanx to the GUT who is driving it,ME <img src="images/icons/wink.gif" border="0">
Hell I talk and talk but the truth is I'm cheap
I'll end up removing the power steering pump,lines,cooler and a couple more odds and ends.
Hopefully I'll get down to 3490lbs
Then I'll work REAL hard on getting the car to hook correctly...
JS
JS
I just heard back from Madman racing and they said the man rack with all power steering accessories removed saved 25 pounds over stock.
That with the Kmember/A-Arms(44 pounds without sway bar), front bumper support (21) and lighter battery (20) is 110 pounds lighter than stock in the nose where it counts. That is worth more than a tenth and a mph in weight transfer alone not to mention the reduction (.03 from bypassing PS pulley)
Cheers,
Chris
Cheers,
Chris
Actually install is a bitch, you have to drill holes in the aarms for it, and get the car aligned after. If you need every last pound off go for it, but I doubt its worth more than .03ths in the big picture. Hardly worth $500.
