How to pick out a 12 bolt???
Old Nov 25, 2001 | 01:26 PM
LJ_Z28's Avatar
Default How to pick out a 12 bolt???
I am going to be purchasing one in the near future. I have no idea what I am going to need when it comes to a 12 bolt...
Tell me what I need...
I have a 1998 Z28 A4. I plan on spraying about a 200 shot and have a 382 All Bore. I am going to have a Vigilante 3600.
Is there any more info yall might need to help me better pick out what I need???
Old Nov 25, 2001 | 01:40 PM
BIGBOS's Avatar
Default Re: How to pick out a 12 bolt???
Go with a 9" inch...they can take a few more gernades than 12 bolts...I've heard of people breaking 12 bolts...
Old Nov 25, 2001 | 03:09 PM
LJ_Z28's Avatar
OK, 9" or 12 bolt, what do I need to go with them, such as gears, etc???
Old Nov 25, 2001 | 06:12 PM
bigSS's Avatar
What size tire you runnin'? That will affect which gear you get...
Old Nov 25, 2001 | 06:24 PM
LJ_Z28's Avatar
I think max I will use 28" tires at the track and 26" tires for the street...
Old Nov 25, 2001 | 07:32 PM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
Does ether one work with a 3 channel abs yet?
Old Nov 25, 2001 | 09:34 PM
WILWAXU's Avatar
[quote]Originally posted by BIGBOS:
<strong>...I've heard of people breaking 12 bolts...</strong><hr></blockquote>
Really. who?
Colonel runs a 12 bolt.
12 bolt is the only option for a ABS (non TCS) only car.
Traction Control(TCS) car can use 9 inch or 12 bolt.
Old Nov 25, 2001 | 10:52 PM
bigSS's Avatar
Apparently you can get a Moser 9" with ABS and TCS, but the Moser 12bolt is also apparently stronger.
I dunno much about autos, but definetley get 33 spline axles. I'd say maybe a 3.73 gear? check out www.prestage.com that might help you better with gear selection.
Old Nov 26, 2001 | 11:24 AM
Camaroholic's Avatar
[quote]Originally posted by WILWAXU:
<strong>
Really. who?
I've heard of many instances of poor build quality by Moser, people twisting the axles on the Strange 12-bolt rears, and broken posi's left and right from both. Another thing to consider... The Eaton HD posi that Moser uses is built by Eaton as a 30 or 31 spline (I don't recall right now), but Moser modifies it to work with the 33 spline axle. That is the weakest link that I know of - a 33 spline Eaton Posi can fail under high HP (guy was running 10s).
When it comes time for me to get a 12-bolt, I'll probably take my chances with a Moser, order the 30- or 31-spline axles (not 33), get the Eaton posi w/ 4.10 gears and ABS. That should hold up well enough for me. I'm planning on running about 118-120 mph in the quarter, with 28" tires, so I should be turning around 6000-6200 RPM in 4th.
-Andrew
Old Nov 26, 2001 | 05:11 PM
WILWAXU's Avatar
Well, I know three deep 10 Second F-bodies running the exact same Strange 12 bolt rear that I have in my Formula. They haven't had ANY trouble.
My Strange came ready to bolt in, filled with fluid. Bolted it in and went! <img src="images/icons/wink.gif" border="0">
Old Nov 28, 2001 | 08:35 PM
BADZ's Avatar
Moderator
I have no problem cutting mid 1.40's 60's with my Strange 33 splines. I also have the benefit of it being quite as a baby..
Old Nov 30, 2001 | 02:35 PM
2quick4u's Avatar
Go with the 12-bolt. I've seen plenty of 9" Ford rears break at the track too. Contrary to popular myth, the 9" is not indestructable.
Old Dec 3, 2001 | 12:42 AM
02 'Hawk's Avatar
My Moser was a ****** headache. failed, rebuilt, failed, shipped back to moser
axles too long, machined.
put it back together and in myself and had a whoppoing month of trouble free driving. I'll never buy one of them again. I'd get strange next time.
Though Moser fixed it and paid shipping, they can kiss my ***. **** poor quality control. Axles were too long BOTH times i got it from them. Both! I even told them about it when i sent it back!
Gears were noisy too.
I wouldnt get 33x either. 30 would be fine and less static loss The Eaton HD is the **** though.
Chris
I've got a long thread on it over at www.camaroz28.com look under user name "Chris' 396 Z
Chris <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
Old Dec 3, 2001 | 03:18 PM
Colonel's Avatar
My Moser 9" was a POS from the get go. Long story. <img src="images/icons/rolleyes.gif" border="0">
BUT, my Moser 12-bolt is awesome! Never a failure with hundreds and hundreds of launches. It's taken me into the 9s and I fully expect it to take me into the 8s in 2002.
I have the 31 spline axles with the HD Eaton. The Eaton is VERY strong and very quiet. <img src="images/icons/cool.gif" border="0">
BTW, Rob Moser himself told me that their 12-bolt for the F-body is stronger than their 9". Why? Because it's not just a reworked 12-bolt. Moser designed the housing new from the ground up. Plus, it's lighter and fits better too (doesn't make it look like you have a lift kit.)
[ December 03, 2001: Message edited by: Colonel ]</p>
Old Dec 4, 2001 | 10:54 AM
Black LS1 T/A's Avatar
Moderator
OK... it won't last, but ....
I ran 10.98 @ 125.83 MPH on stock tranny and stock rear axle. <img src="images/icons/grin.gif" border="0">
I've raced about every other week since March and nearly every week since I got the SC (late September).
Old Dec 4, 2001 | 11:13 AM
J'sRamAir's Avatar
<strong>
Really. who?</strong><hr></blockquote>
He may be partially referring to this thread: https://ls1tech.com/ubb/cgi-bin/ulti...c&f=2&t=000225
