replacing bearings
so my plans are to buy a rear axle bearing and 2 carrier bearings, take the rear end apart, and then when i find the bad bearing, replace it, and take the remaining bearings back. but, the most i've ever done on a rear end is replace the fluid, so i need a little help with the rest.
if anyone could direct me to a site explaining how to do this, or if anyone wants to go into great detail (tools, time, procedures, etc), that would be excellent! something i hate more than anything is going into an install not having a single clue what i'm doing! but this noise is bad, and it need to be taken care of immediately!
http://toolcraze.com/Merchant2/merch...gory_Code=pull
now i'm torn between axle and wheel bearing. what do you guys think? i'm probably going to attempt the wheel bearing this weekend unless i get some strong advice to not do such a thing.
If it is not obviously the axle bearing, then once you have the axles out it is easy to take out the carrier by removing the caps and prying the carrier out. Make sure you notice the shims between the bearing races and the housing, put them back in the same spots (l&r). Once you have it out, you can check the carrier bearings easy.
If you still have not found the problem, at this point you are only one nut away from checking the pinion bearings. Get a pinion holding tool and a torque wrench from Autozone, measure the torque it takes to remove the nut, so you can put it back with the same torque if the bearings are ok (if you replace the bearings, you will need to reset the pinion depth - gear setup).
If I've got anything wrong here, someone else chime in, but I don't think I have forgotten anything. Good luck, let us know how it goes, and feel free to pm or email if you have problems.
I'm building a complete rear right now, and putting all new bearings in it just so I don't have to fool with it again for years.
firstly, the passenger side is the bad side. can i leave my driver's side rim/tire/brakes on and not even touch it then? will the c-clip still fall if i just push in the passenger side axle?
secondly, which bearing tool do i rent at a-zone? i've heard some work well and others do not. how do i put the tool on the bearing in order to get it off? how do i get the new bearing back on? what about the seal? do i need to have grease to put on the seal and bearing when i put it back on? any other pointers?
i have to drive out of town next week, so it's imperative i try to get this taken care of this weekend, since i was advised to not drive long distances on this bearing. please let me know if you know the answers to my questions!!
also, anyone know the length of an f-body axle?
The tool you need is an axle bearing puller. It is pretty self explanatory, select the right size tip ( you can use your new bearing to tell which one it is), insert it in the housing through the bearing and pull back until it is tight. Tighten the nut and washer so it doesn't move, hook up the slide hammer, and start yanking.
Just tap the new one in using a bearing driver - also available at azone. They'll hook you up with the right stuff.
No grease needed, the lube in the rear will take care of that. If you have a Torsen posi you should go back with some redline or mobil one synthetic, Royal Purple is fine too.
What do you need the length for ?
do i need silicone for the rear gasket, or not? some people say to use an assload, others say not to use any. i just don't want it to leak...
Successful silicone is all in the technique, too much or overtightened and you will squeeze it out and it will leak. Too little and it will leak. Try to reuse the gasket, your best bet for a non-leaker. If you tear it, use silicone to glue the tear back together.
Good luck !
