12 Bolt strong enough?
A 9" is pretty much overkill. Your better off with a 12 bolt because that will probably hold up just as good and you won't have as much drivetrain loss. Like mike's02ls1 said, just get 33 spline axles w/ a spool setup and you should be fine. If your worried about it go with 4.30s in the rear. That way you'll spin (to a 1.6 60') before you break.
My .02
