9" with soft locker
My locker has seen three different gears, and about 300 passes. It's doing great. I may end up selling the whole rearend at some point and getting a 35 or 40 spline one since I make almost 800rwhp.
Here is a pic of mine:
https://ls1tech.com/forums/attachmen...chmentid=17940
I was worried the ride would be real harsh but the rear end feels very solid and tight. When I take a tight corner the wheels jerk a little but its kind of cool. it really drives a lot better than I was expecting. I cant wait to break the gears in and get on it
Anybody that drove 60's Ford muscle cars will tell you they are noticable but needed if you want both tires to turn EVERY time you launch. On the street just know it's there, keep rear tire air pressures equal and enjoy the clicking!
For the guys running the soft locker (I assume they're all 31 spline?) can you give me a sense of exactly what normal street driving is like? You know, I'm at the stoplight on an uphill and I make a right turn... is my car going to lurch and clunk (be more prone to stalling?) or am I just going to hear a mild clicking sound from the rear? Or I'm parallel parking...
Just trying to get a sense of whether the quirks for the soft locker are mainly generating mild noise or actually making the car difficult to manuever.
Thanks in advance for your input,
Rich
Rich
CMC
Any hints? Also curious if the TruTrack posi is popular right now just because it's a newer flavor... or is it really significantly better than the other posi units?
car in corners is very picky when it comes to how you accelerate or better yet dont through corners
best word to describe the car when turning is very twitchy
Things I've learned from driving mine. In tight turns push the clutch in and coast. For a normal turn either coast through it or use enough gas to keep it locked and it won't lurch sideways. On entrance and exit ramps my car can still hold a pretty good amount of speed (still has front sway bar and wide tires) but you can tell that one tire is spinning a little bit cause it's still locked, but you have to use the gas just right in these type turns or it will start jumping sideways and come out from under you. In the rain, well you pretty much have a spool.
Lockers are really fun when you wanna get stupid though. You can power slide so easily and it's so much easier to control it w/ both tires locked together, I don't have to fight the wheel like a used to.
Moser 9" Bolt-In Housing
Assembled Strange Center Section w/ Trach-Tech Locker, 3.50-6.50 Gear, and 1350 Yoke
Moser 31/35 Spline Axles, Bearings, and Studs
Accepts Factory/Aftermarket Brakes & Torque Arm
Perfect Upgrade for High Horsepower and Manual Trans Cars
Assembly Available for a Complete Bolt-in Unit!
So this is what I want?
This is the soft locker?
